Modular Configuration
MFPCS also supports the modular Solution Designer configuration for MFP. It will be treated as a nontemplate configuration and the build/patch process remains the same for both modular and non-modular configuration. The customer needs to generate the configuration for the selected modules and custom modules and upload the generated configuration for build/patch using the same existing process. If SD config was used during build/patch, standard workflow manager tasks configured for MFPCS will be available to the user under the Workflow Manager. The customer can copy the required taskflows or create their own taskflows and then publish the same in order to use the same in the application.
See the Oracle Retail Merchandise Financial Planning Cloud Service Starter Kit Guide to get the solution designer MFP GA modules and also its related batch control and interface.cfg files. See the Oracle Retail Predictive Application Server Cloud Edition User Guide Workflow Manager section for more details about the configuration of Workflow Flows.
See the Oracle Retail Predictive Application Server Cloud Edition Solution Designer User Guide for more details about how to configure new custom modules.
