D Sample Public File Transfer Script for RI and AIF
#!/bin/bash
# Sample Public FTS script
### EDIT HERE to reflect your environment
BASE_URL="https://__YOUR_TENANT_BASE_URL__"
TENANT="__YOUR-TENANT_ID__"
IDCS_URL="https://_YOUR__IDCS__URL__/oauth2/v1/token"
IDCS_CLIENTID="__YOUR_CLIENT_APPID__"
IDCS_CLIENTSECRET="__YOUR_CLIENT_SECRET___"
IDCS_SCOPE=”rgbu:rsp:psraf-__YOUR_SCOPE__”
### FINISHED
clientToken() {
curl -sX POST "${IDCS_URL}" \
--header "Authorization: Basic ${IDCS_AUTH}" \
--header "Content-Type: application/x-www-form-urlencoded" \
--data-urlencode "grant_type=client_credentials" \
--data-urlencode "scope=${IDCS_SCOPE}" | jq -r .access_token
ping() {
echo "Pinging"
curl -sfX GET "${BASE_URL}/${TENANT}/RIRetailAppsPlatformServices/services/private/FTSWrapper/ping" \
--header 'Accept: application/json' \
--header 'Accept-Language: en' \
--header "Authorization: Bearer ${CLIENT_TOKEN}" | jq
listPrefixes() {
echo "Listing storage prefixes"
curl -sfX GET "${BASE_URL}/${TENANT}/RIRetailAppsPlatformServices/services/private/FTSWrapper/listprefixes" \
listFiles() {
echo "Listing files for ${1}"
curl -sfX GET "${BASE_URL}/${TENANT}/RIRetailAppsPlatformServices/services/private/FTSWrapper/listfiles?prefix=${1}" \
deleteFiles() {
echo "Deleting files"
json=$(fileCollection $@)
curl --show-error -sfX DELETE "${BASE_URL}/${TENANT}/RIRetailAppsPlatformServices/services/private/FTSWrapper/delete" \
--header 'content-type: application/json' \
--header "Authorization: Bearer ${CLIENT_TOKEN}" \
-d "${json}" | jq
fileMover() {
movement="${1}"
shift
requestPAR "${movement}" "${json}"
fileCollection() {
local json="{ \"listOfFiles\": [ __FILES__ ] }"
sp="${1}"
shift
while (( "${#}" )); do
list="${list} { \"storagePrefix\": \"${sp}\", \"fileName\": \"${1}\" }"
if [[ ${#} -gt "1" ]]; then
list="${list},"
fi
shift
done
echo "${json/__FILES__/${list}}"
requestPAR() {
use="${1}"
echo "Requesting PARs for ${use}"
pars="$(curl --show-error -sfX POST "${BASE_URL}/${TENANT}/RIRetailAppsPlatformServices/services/private/FTSWrapper/${use}" \
-d "${2}")"
if [[ "$?" -ne "0" ]]; then
echo "Error retreiving PAR, check files specified."
echo "${pars}"
exit 1
fi
list=$(jq -r ".parList[]|[.name, .accessUri]|@csv" <<< "${pars}")
while IFS='' read -r line; do
fn=$(echo ${line}|cut -d\, -f1|tr -d \")
par=$(echo ${line}|cut -d\, -f2|tr -d \")
if [[ ${use} == "upload" ]]; then
echo "Uploading ${fn} to ${par}"
curl -o log -X PUT --data-binary "@${fn}" "${par}"
else
echo "Downloading ${fn} from ${par}"
curl -o ${fn} -X GET "${par}"
fi
done <<< "${list}"
#Entry point
IDCS_AUTH=$(echo -n ${IDCS_CLIENTID}:${IDCS_CLIENTSECRET} | base64 -w0)
CLIENT_TOKEN=$(clientToken)
case "${1}" in
ping)
ping
listprefixes)
shift
listPrefixes
listfiles)
shift
listFiles ${@}
deletefiles)
shift
deleteFiles ${@}
uploadfiles)
shift
fileMover upload ${@}
downloadfiles)
shift
fileMover download ${@}
echo "Usage: $0"
echo " ping : test service functionality"
echo " listprefixes : list registered prefixes"
echo " listfiles [prefix] : list files within a prefix"
echo " deletefiles [prefix] [file1] [file2] ... : delete files with this prefix"
echo " uploadfiles [prefix] [file1] [file2] ... : upload files with this prefix"
echo " downloadfiles [prefix] [file1] [file2] ... : download files with this prefix"
echo
exit 0
esac
