Adjustment Data Requirements
Adjustments data (ADJUSTMENT.csv) is used to capture manual changes to stock on hand made for any reason
that does not fall into one of the other categories like sales or receipts. Adjustments are used only in Planning and RI applications.
| Rule | Explanation |
Adjustment Types |
The adjustments are provided using a type code, with 3 specific codes supported:
Only types |
Reason Codes |
Reason codes are used to identify the specific type of adjustment that occurred for that item, location, and date. If you are loading data for Planning apps, then they are not required because Planning apps do not look at reason codes. They are only used for RI reporting. There are no required codes; it will depend on the data in your source system. The codes should be numerical, and there is a Description field that must also be provided for the display name. |
Positive and Negative Values |
Adjustments should be positive by default. A positive adjustment on the input file means a decrease in the stock on hand at the location. A negative adjustment means an increase to stock on hand (basically you have adjusted the units back into the location’s inventory, which is less common). When the data is sent to MFP, the default planning import will invert the signs for the positive adjustments to become subtractions to inventory. |
In most cases, you will be providing the same set of adjustment columns for any application. These columns are listed below with additional usage notes.
| Column Header | Usage |
ITEM |
Must be the transaction level item or SKU number and must have a record in the |
ORG_NUM |
Must be the location number where the item inventory was adjusted. Must have a record in |
DAY_DT |
The date that the adjustment occurred on. Adjustments can occur on any date both in history and nightly batch files. |
INVADJ_TYPE_CODE |
Indicates the type of adjustment to inventory using transaction codes |
INVADJ_QTY INVADJ_COST_AMT_LCL INVADJ_RTL_AMT_LCL |
The units and total cost/retail values for the adjustment. The cost and retail amounts may have varying calculations in your source system depending on how shrink and non-shrink inventory adjustments are determined. Adjustments can be negative or positive depending on whether inventory is being removed or added to the stock on hand. The sign is reversed by MFP, meaning negative amounts on the input will display as positive values on the MFP measures. |
LOC_CURR_CODE DOC_CURR_CODE |
The currency codes linked to the cost and retail amounts on the adjustment data. The
values in these fields will control how the system converts the amount (such as |
