Automated History Loads
Once you have performed your history loads manually a couple of times (following all steps in later sections) and validated
the data is correct, you may wish to automate the remaining file loads. A standalone process flow RI_FLOW_ADHOC is available in POM that can run the fact history loads multiple times using your specified start times. Follow the steps
below to enable this process:
Upload multiple ZIP files using FTS, each containing one set of files for the same historical period. Name the files like
RAP_DATA_HIST.zip,RAP_DATA_HIST.zip.1,RAP_DATA_HIST.zip.2and so on, incrementing the index on the end of the zip file name after the first one. -
In the POM batch administration screen, ensure all of the jobs in the
RI_FLOW_ADHOCare enabled, matching your initial fact history standalone runs. The following processes in the process flow are common to all runs and all jobs should be enabled in them:-
FLOW_LOAD_START_PROCESS
FLOW_LOAD_END_PROCESS
CLEANUP_C_LOAD_DATES_FLOW_PROCESS
ZIP_FILE_LOAD_FLOW_PROCESS
FACT_FLOW_END_PROCESS
Schedule the standalone flows from Scheduler Administration to occur at various intervals throughout the day. Space out the cycles based on how long it took to process your first file.
Monitor the load progress from the Batch Monitoring screen to see the results from each run. Monitor the table
C_HIST_FILES_LOAD_STATUSto verify the ZIP files you uploaded were all processed successfully. Validate that data is being loaded successfully in your database periodically throughout the standalone runs. If a run fails for any reason, it will not allow more runs to proceed until the issue is resolved.
