Configure POM Integrations
Retailers often have external applications that manage batch execution and automation of periodic processes. They might also require other downstream applications to be triggered automatically based on the status of programs in the Retail Analytics and Planning. POM supports the following integrations that should be considered as part of your implementation plan.
Table 5-5 POM Integrations
| Activity | References |
Trigger RAP batches from an external program |
POM Implementation Guide > Integration > Invoking Cycles in POM |
Trigger external processes based on RAP batch statuses |
POM Implementation Guide > Integration > External Status Update |
Add external dependencies into the RAP batch to pause execution at specific points |
POM Implementation Guide > Integration > External Dependency |
