Custom Batch Control Validation
The extensible / custom batch control files need to follow the guidelines previously to futureproof the retailer. That means the retailer should receive software updates without breaking the existing customizations. To ensure that the batch control file guidelines are adhered to, a batch control validation module has been added.
The ra_config_validation.sh script has an optional parameter -b <parent directory of batch
control files> which will validate the batch control files.
Batch control validation rules:
Apart from
batch_oat_list.txt, none of the set names in the other batch control files can be overridden. That is, GA set names cannot be used in custom batch control files. -
None of the custom batch control files can call the GA set names.
The
batch_calc_list.txtfile can only specify custom rule group names. Cannot specify expressions and GA rule group names. -
The
batch_loadmeas.txt_listfile can specify measures that are listed in the Loadable or Writable list of the published measures in thepublished<app>Measures.propertiesfile -
The
batch_exportmeas_list.txtfile can specify measures that are listed in the ReadOnly or Writable list of the published measures in thepublished<app>Measures.propertiesfile. -
All custom set names should have a prefix of
c_.
The batch control validation is called automatically during domain build or patch. It is also called when the batch control files are uploaded using the Upload Batch Control files from OAT.
