Download Archives
For RAP files that are automatically archived as part of the batch process, you have the ability to download these files for a limited number of days before they are erased (based on the file retention policy in your OCI region). Archive files are added to sub-folders so the steps are different from a standard download.
POM job logs will show the path to the archive
For example:
incoming-10072022-163233/RAP_DATA.zip -
Create the directory in your local server matching the archive name.
For example:
mkdir incoming-10072022-163233 -
Use the
downloadfilescommand with theris/archiveprefix and the file path as the sub-folder and filename together.For example: sh file_transfer.sh downloadfiles ris/archive incoming-10072022-163233/RAP_DATA.zip
