Example #3: Full dimension load
You have a set of dimension files you want to process using the initial dimension load ad hoc processes in POM.
File to upload: RAP_DATA_HIST.zip
Zip file contents:
PRODUCT.csv -
PRODUCT.csv.ctx -
ORGANIZATION.csv -
ORGANIZATION.csv.ctx -
ATTR.csv -
ATTR.csv.ctx -
PROD_ATTR.csv -
PROD_ATTR.csv.ctx -
EXCH_RATE.csv -
EXCH_RATE.csv.ctx
