Fact and Dimension Relationships
When a fact interface such as SALES.csv is loaded into the data warehouse, the programs perform many joins
between the incoming data and the associated dimensions and hierarchies. The data warehouse enforces strict data integrity
rules across tables; this requires that, for every fact record, all associated dimension records are present and active. For
a record to be considered the active dimension record, it must have effective dates that encompass the same date on the fact
record. For example:
A record in the
SALES.csvfile for a given nightly batch cycle has key values of:-
ITEM = 1285001
ORG_NUM = 4400
DAY_DT = 05-MAY-23
For this record to be loaded successfully, the item, location, and date must all be present and active within the associated dimension tables:
For the item, a record must exist in
W_PRODUCT_D_RTL_TMPhaving a matching item number in columnPROD_IT_NUM, and the value ofDAY_DTfrom the sale must be betweenSRC_EFF_FROM_DTandSRC_EFF_TO_DT. -
For the location, a record must exist in
W_INT_ORG_DH_RTL_TMPhaving a matching location number in columnORG_NUM, and the value ofDAY_DTfrom the sale must be betweenEFFECTIVE_FROM_DTandEFFECTIVE_TO_DT. -
For the date, a record must exist in
W_MCAL_DAY_Dhaving the same date onMCAL_DAY_DT.
If the fact record has other key columns such as suppliers, buyers, reasons, statuses, and so on, then similar dimension joins may be used across all of them.
If any join between the fact table and dimension tables is unable to find matches based on the above criteria, then the fact record will not load into the data warehouse and will instead be rejected and moved into separate tables for review.
