PL/SQL Best Practices
Number PL/SQL Best Practice Comments
1
Use the functions and procedures provided by Oracle
Try minimize writing your own functions and procedures.
2
Use Oracle's Searching and Sorting routines
The built-in routines are highly optimized.
3
Take advantage of the ways Oracle performs control logic evaluation
If you have multiple conditions that control branching, Oracle evaluates them in the order you provide them. It will not evaluate all the conditions unless it needs to.
Order your conditions in a manner that allows Oracle to take short cuts.
If there are two conditions, then put the most restrictive condition first.
4
Avoid implicit datatype conversions
Avoid comparing variables that have different datatypes. The time spent on the implicit datatype conversions during each execution could be reclaimed if the datatypes were converted to a consistent set prior to comparisons.
5
Size VARCHAR2 variables properly
VARCHAR2(1000)   vs.  VARCHAR2(2000)
If the size is less than 2000, then PL/SQL allocates enough memory to hold the declared length of the variable.
But if the size is greater than or equal to 2000, PL/SQL dynamically allocates only enough memory to handle the actual value.
6
Use PL/SQL within SQL statements
There are potential performance gains by including a PL/SQL function as part of a query.
7
Use DBMS_PROFILER to identify problems
Capture the profiling statistics to identify the lines in your code that take the most time.
8
Use PL/SQL features for Bulk operations
Avoid row by row operations and use FORALL and  BULK COLLECT.
9
Use JOIN methods carefully
Based on the conditions in your query, the available indexes, and available statistics, the optimizer chooses which JOIN operation to use. You can influence the optimizer to use a different JOIN method.
