Receipts Data Requirements
Receipts data (RECEIPT.csv) is used specifically for receipt transactions where inventory units are received
into an owned location (like a store or warehouse), and that receipt impacts the stock on hand for the location. The file
is used for several purposes throughout RAP: it is needed by MFP for inventory plans, by IPO and LPO for determining first
and last receiving dates by item/location, and by RI for reporting on receipt activity. The receipts data must be loaded in
parallel with inventory position if AIF modules are being implemented, because the calculations for IPO/LPO are done up front
during each load of inventory position and receipt files.
| Rule | Explanation |
Receipt Types |
The receipts are provided using a type code, with 3 specific codes supported:
MFP GA solution only uses type 20 transactions but the rest of the RAP solutions use all types. |
Receipts vs. Transfers |
Transfer receipts are not the same thing as transfers ( |
Unplanned Receipts |
It is possible for a location to receive inventory it did not ask for (for example, there is no associated PO or allocation linked to those units). Such receipts should still appear as a type 44~T receipt transaction, so long as those units of inventory do get pulled into the location’s stock on hand. |
In most cases, you will be providing the same set of receipt columns for any application. These columns are listed below with additional usage notes.
| Column Header | Usage |
ITEM |
Must be the transaction level item or SKU number and must have a record in the |
ORG_NUM |
Must be the location number where the item is received. Must have a record in |
DAY_DT |
The date that the receipt occurred on. Receipts can occur on any date both in history and nightly batch files. |
INVRC_TYPE_CODE |
Indicates the type of receipt into a location using merchandising transaction codes |
INVRC_QTY INVRC_COST_AMT_LCL INVRC_RTL_AMT_LCL |
The units being received and the total cost/retail value of those units relative to the receiving location. |
LOC_CURR_CODE DOC_CURR_CODE |
The currency codes linked to the cost and retail amounts on the receipt data. The values
in these fields will control how the system converts the amount (such as |
