Rules for Adding Measures
The following rules apply when adding measures to the application configurations:
Customers may add new custom measures into the custom solution and reference them as an external measure in the extensible solutions.
Customers can also add new custom metrics as a major component in the extensible solutions. It is strongly recommended to not mix custom metrics with application metrics.
Custom measures should follow the naming convention and should begin with a
C_orc_prefix. -
Only the published GA measures can be used in custom rules and custom workbooks. Only writable GA measures can be used on the left-hand side of a rule expression. The read-only GA measures can only be used on the right-hand side of the rule expression.
