Usage Examples
The following examples show how to leverage the PDS extract processes to move data from the data warehouse tables to the PDS staging tables, where the data can be picked up by the Planning applications.
Scenario 1: Initial Dimension Extract
Perform the initial loads into the data warehouse as described in the section Initialize Dimensions.
Enable all jobs in the ad hoc process
LOAD_PDS_DIMENSION_PROCESS_ADHOCand execute it. -
Verify that data has been moved successfully to the target tables, such as
W_PDS_CALENDAR_D,W_PDS_PRODUCT_D, andW_PDS_ORGANIZATION_D.
Scenario 2: Initial Sales Extract
Perform the initial sales loads into the data warehouse as described in the section Sales History Load.
Enable the job
W_PDS_SLS_IT_LC_WK_A_JOBin the ad hoc processLOAD_PDS_FACT_PROCESS_ADHOCand execute the process. -
W_PDS_SLS_IT_LC_WK_AandW_PDS_GRS_SLS_IT_LC_WK_A. -
Repeat the same steps for any other transactional history loads, such as adjustments, transfers, and RTVs (using the appropriate PDS job as described in the prior section).
Scenario 3: Initial Inventory Extract
Perform the initial inventory loads into the data warehouse as described in the section Inventory Position History Load.
Open the
C_SOURCE_CDCtable in Manage System Configurations and locate the row forW_RTL_INV_IT_LC_WK_A. Edit the values in theLAST_MIN_DATEandLAST_MAX_DATEcolumns to fully encompass your range of historical dates in the inventory history. -
Enable the job
W_PDS_INV_IT_LC_WK_A_INITIAL_JOBin the ad hoc processLOAD_PDS_FACT_INITIAL_PROCESS_ADHOCand execute the process. -
If the job fails with error code “ORA-01403: no data found,” it generally means that the dates in
C_SOURCE_CDCare not set or do not align with your historical data. Update the dates and re-run the job. -
W_PDS_INV_IT_LC_WK_A.
Scenario 4: Updated Data Extracts
Load additional history data as required for the project. For example, you may have started with one month of data for testing and are now going to load an additional 2 years of data.
If the
C_LOAD_DATES_CLEANUP_ADHOCprocess was not run at the start of your current data load, run it now to ensure there are no previous run statuses from past PDS export runs that will interfere with new runs. -
Run
LOAD_PDS_DIMENSION_PROCESS_ADHOCto ensure the dimensions for PDS are in sync with the new history data being loaded. -
Review
C_SOURCE_CDCand alter the minimum/maximum dates on each table, if required. If you want to re-push your entire history for a fact, including the previously loaded data, then you will need to adjust the dates before running the extracts. -
Run
LOAD_PDS_FACT_PROCESS_ADHOCfor all the facts, such as sales and receipts, that have had new history loaded in the data warehouse. -
Run
LOAD_PDS_FACT_INITIAL_PROCESS_ADHOCto pull the desired range of inventory periods. -
Verify the target tables contain the expected data before starting the import into Planning applications.
