RPASCE Special Expression - execplsql
The special expression execplsql provides the ability to invoke the customer uploaded PL/SQL
functions and procedures from within the RPASCE rules and expressions framework. Both functions and procedures are supported.
Also execplsql is variadic and can take an arbitrary number of arguments that can be of different
types according to the PL/SQL signature. The number and type depend on the signature of the function or procedures being executed.
The first two arguments to execplsql are reserved to indicate the package name and the function or procedure
name to be executed.
Example
drdvsrcti<-execplsql("RP_CUSTOM_PKG","sum",drdvsrctt, adhdlcratet, add2locopnd)In this example the LHS measure drdvsrcti is a scalar integer measure. It will be set to the
integer value returned by the function named sum in the customer uploaded package RP_CUSTOM_PKG.
