Validating the Customized Configuration
A script, ra_config_validation.sh, has been provided to allow the customer or implementer to validate
that the customizations conform to the rules outlined above. For details of the script, refer to Configuration Validation.
This script can be run on Windows with the application starter kit. To do this, the implementer will need to make sure that they have a pristine copy of the GA configuration as well as the custom configuration.
For example, if the GA configuration has been copied to C:\Oracle\configurations\GA\RDF and the custom
configuration is in C:\Oracle\configurations\RDF, then the script can be called from a Cygwin zsh shell:
$RPAS_HOME/bin/ra_config_validation.sh -n RDF -d /cygdrive/c/Oracle/configurations -c /cygdrive/c/Oracle/configurations/GA/RDF/RDF.xml
