6 Managing Metric Visibility
When using Retail Insights for reporting on your data, the main subject areas each
contain more than 10,000 metrics and attributes. Many of these may not contain data in
your environment and could be hidden from the Oracle Analytics interface to improve the
user experience. Metric visibility is controlled using a data warehouse configuration
table C_RPD_METRIC_VISIBILITY. The workflow required to make changes to
this data is detailed below.
From your non-production environment:
- Login to Innovation Workbench (AIF APEX) in your Non-Prod environment or navigate to it from Retail Home.
- Query the table
C_RPD_METRIC_VISIBILITYto review the data for metric visibility. By default, all metrics are visible (ACTIVE_FLG = Y). - Run SQL update statements to change the value of the
ACTIVE_FLGcolumn toNon rows that should be hidden from the UI.
The updates will not immediately reflect in the Oracle Analytics user interface due to server caching of the configurations. Updates are applied any time application patching or upgrades are performed, or if you request the updates to be applied manually by raising a Service Request to Oracle. For testing the changes immediately in your non-prod environment, open a service request for assistance.
When you are satisfied with the updates, perform the following steps to migrate the configurations to production:
- Login to AI Foundation in your Non-Prod environment or navigate to it from Retail Home.
- From the task menu, select the Control and Tactical Center > Manage
System Configurations task. From the dropdown menu showing the list
of configuration tables, select
C_RPD_METRIC_VISIBILITY. - Export the table to Excel, keeping the default filename and data type
C_RPD_METRIC_VISIBILITY.csv). Do not modify the contents of the file, as the configuration import/export feature is strictly for migration of settings between environments. - Now go to the same screen in your Prod environment and select the
C_RPD_METRIC_VISIBILITYtable. Import theC_RPD_METRIC_VISIBILITY.csvfile into theC_RPD_METRIC_VISIBILITYtable using the Import button on the action bar. - If you need the configuration updates to be applied immediately, raise a new service request for assistance.
Once the updates are applied, the metrics having ACTIVE_FLG=N will no
longer be shown to any user in the system when creating or viewing reports. You cannot
add them to new data visualizations, publisher data models, or custom datasets. Existing
objects that have hidden metrics may not return data properly until the hidden metrics
are deleted from them. If you need to restore the visibility of a metric that was hidden
by accident or cannot be hidden due to its use in existing objects, repeat the process
above but change the ACTIVE_FLG back to Y, and then
raise a new Oracle Service Request to apply the updates.
