Fact Data Key Columns
Fact data files, such as sales and inventory, share many common characteristics and standards that can be followed regardless of the specific file. The table below summarizes those key elements and their minimum requirements. You will generally always want to populate these fields where they exist on an interface file.
Table 6-7 Common Fact Data Fields
| Column Header | Usage |
ITEM |
Unique identifier of a transaction item. Must align with the product
records in the |
ORG_NUM |
Unique identifier of an organizational entity. Must align with the
location records in the |
DAY_DT |
Transaction date or business date for the fact data entry, formatted
as YYYYMMDD. Must be a valid date within the range of periods in |
RTL_TYPE_CODE |
Retail types define a general category for the record that varies
by interface. For Sales and Markdowns, it must be one of |
*_QTY |
Fields ending with |
*_AMT_LCL |
Fields containing |
DOC_CURR_CODE |
The original document currency of the record in the source system.
For example, a sale made in Canada may have a value of |
LOC_CURR_CODE |
The local operating currency of your main office or headquarters.
A company based in the United States would use |
Nearly all fact files share a common intersection of an item, location, and date as specified above. Such files are expected to come into the platform on a nightly basis and contain that day’s transactions or business activity.
Most fact data also supports having currency amounts in their source currency, which is then automatically converted to your primary operating currency during the load process. There are several currency code and exchange rate columns on such interfaces, which should be populated if you need this functionality. The most important ones are shown in the list above, and other optional column for global currencies can be found in the Interfaces Guide. When you provide these fields, they must all be provided on every row of data, you cannot leave out any of the values or it will not load properly.
In addition to the commonly used fields, most files have other key columns that can be used to specify important details about the record. Some of these fields are marked as optional in the full interface specifications, meaning that if they are not provided, then some default values will be set for you.
Table 6-8 Additional Fact Data Key Columns
| File | Column Header | Usage |
SALES |
SLS_TRX_ID |
Unique identifier of a sales transaction. By default, it is expected sales data will come at the most granular level (transaction-line). If you are not able to provide transaction-level data, specify another unique value in this field. |
SALES |
MIN_NUM |
Hour and minute of the transaction in 24-hour, 4-digit format; for
example, 11:23 PM would be 2323. Currently only used in Retail Insights reporting; default to |
SALES |
IT_SEQ_NUM |
Sequence of a line in the transaction. Every line of a transaction must have its own sequence number. This facilitates uniqueness requirements where the same item could have multiple lines. Without a unique sequence number, the line would not be unique on the input file and the system would see them as duplicate records (and they will not load properly as a result). |
SALES |
PROMO_ID PROMO_COMP_ID |
This two-part identifier maps to the Promotion and Offer associated with a transaction line. They are required if you wish to load sales by promotion for Retail Insights or certain Science modules such as Demand Transference. |
SALES |
CASHIER_ID SALES_PERSON_ID |
Cashier or salesperson associated with the transaction. Currently used only for Retail Insights. |
SALES |
CO_HEAD_ID CO_LINE_ID |
Order ID and line ID for a customer order, such as an online sale. Currently only used by Retail Insights. |
SALES |
CUSTOMER_NUM CUSTOMER_TYPE |
Customer identifier on a sales transaction, which is a critical
piece of information for many Science modules, such as Customer Segmentation and Consumer Decisions Trees. |
SALES_PACK |
ITEM PACK_NUM |
INVENTORY |
CLEARANCE_FLG |
RECEIPT |
INVRC_TYPE_CODE |
Indicates the type of receipt into a location using merchandising
transaction codes |
ADJUSTMENT |
REASON_CODE |
User-defined reason for making the inventory adjustment. Currently used only for Retail Insights. |
ADJUSTMENT |
INVADJ_TYPE_CODE |
Indicates the type of adjustment to inventory using merchandise
transaction codes |
TRANSFER |
FROM_ORG_NUM FROM_CLEARANCE_FLG FROM_* |
Transfers are created for both the source of the transfer (the FROM
location) and the destination (the TO location). Fields not having a |
TRANSFER |
TSF_TYPE_ID |
The type of transfer in the source system. It must be |
RTV |
INV_STATUS |
Status codes for the type of inventory being returned to a vendor, such as damaged or unsellable. |
Here are sample records for commonly used historical load files having a small set of fields populated. These fields are sufficient to see results in RI reporting and move the data to RSP or MFP but may not satisfy all the functional requirements of those applications. Review the interfaces guide for complete details on required/optional columns on these interfaces.
SALES.csv:
ITEM,ORG_NUM,DAY_DT,MIN_NUM,RTL_TYPE_CODE,SLS_TRX_ID,PROMO_ID,PROMO_COMP_ID,CASHIER_ID,REGISTER_ID,SALES_PERSON_ID,CUSTOMER_NUM,SLS_QTY,SLS_AMT_LCL,SLS_PROFIT_AMT_LCL,RET_QTY,RET_AMT_LCL,RET_PROFIT_AMT_LCL,TRAN_TYPE,LOC_CURR_CODE,DOC_CURR_CODE
1235842,1029,20210228,0,R,202102281029,-1,-1,96,19,65,-1,173,1730,605.5,0,0,0,SALE,USD,USD
1235842,1029,20210307,0,R,202103071029,-1,-1,12,19,55,-1,167,1670,584.5,0,0,0,SALE,USD,USD
1235842,1029,20210314,0,R,202103141029,-1,-1,30,18,20,-1,181,1810,633.5,0,0,0,SALE,USD,USD
INVENTORY.csv:
ITEM,ORG_NUM,DAY_DT,CLEARANCE_FLG,INV_SOH_QTY,INV_SOH_COST_AMT_LCL,INV_SOH_RTL_AMT_LCL,INV_UNIT_RTL_AMT_LCL,INV_AVG_COST_AMT_LCL,INV_UNIT_COST_AMT_LCL,PURCH_TYPE_CODE,DOC_CURR_CODE,LOC_CURR_CODE
72939751,1001,20200208,N,0,0,0,104.63,0,48.52,0,USD,USD
73137693,1001,20200208,N,0,0,0,104.63,0,48.52,0,USD,USD
75539075,1001,20200208,N,0,0,0,101.73,0,47.44,0,USD,USD
PRICE.csv:
ITEM,ORG_NUM,DAY_DT,PRICE_CHANGE_TRAN_TYPE,SELLING_UOM,STANDARD_UNIT_RTL_AMT_LCL,SELLING_UNIT_RTL_AMT_LCL,BASE_COST_AMT_LCL,LOC_CURR_CODE,DOC_CURR_CODE
89833651,1004,20200208,0,EA,93.11,93.11,53.56,USD,USD
90710567,1004,20200208,0,EA,90.41,90.41,50.74,USD,USD
90846443,1004,20200208,0,EA,79.87,79.87,44.57,USD,USD
