Files Types and Data Format
The shared platform data files discussed in this chapter may use a standard comma-delimited (CSV) file format, with text
strings optionally enclosed by quotation marks or other characters. The files expect the first line to be column headers,
and lines 2+ should contain the input data. This applies to any filename ending in .csv. For specific columns
in each of these files, the following standards can be used as a guideline (though they can be changed by configuration options).
Table 7-1 Foundation File Formatting
| Datatype | Format | Example | Explanation |
Number |
0.00 |
340911.10 |
Numbers should be unformatted with periods for decimal places. Commas or other symbols should not be used within the numerical values. |
Character |
“abc” |
“Item #4561” |
Any alphanumeric string can be optionally enclosed by quotation marks to encapsulate special characters such as commas in a descriptive value. |
Date |
YYYYMMDD |
20201231 |
Dates should be provided as simple 8-digit values with no formatting in year-month-day sequences. |
