FTS API Specification
An example shell script implementing these API calls can be found in Sample Public File Transfer Script for Planning Apps. The sample script will require all of the parameters discussed so far in this chapter to be added to it before it can be used to issue FTS commands. Refer to the table below for a more detailed list of services available in FTS.
Ping
Returns the status of the service, and provides an external health-check.
Method
GET
Endpoint
{baseUrl}/services/private/FTSWrapper/ping
Parameters
Common headers
Request
None
Response
{ appStatus:200 }
The appStatus code follows HTTP return code standards.
List Prefixes
Returns a list of the known storage prefixes. These are analogous to directories, and are restricted to predefined choices per service.
Method
GET
Endpoint
{baseUrl}//services/private/FTSWrapper/listprefixes
Parameters
Common headers
Request
None
Response
A JSON array of strings containing the known prefixes.
List Files
Returns a list of the file within a given storage prefix.
Method
GET
Endpoint
{baseUrl}/services/private/FTSWrapper/listfiles
Parameters
Common headers
Request
Query parameters (…/listfiles?{parameterName}) that can be appended to the URL to filter the request:
prefix – the storage prefix to use
contains – files that contain the specified substring
scanStatus – file status returned by malware/antivirus scan
limit – control the number of results in a page
offset – page number
sort – the sort order key
Response
A JSON resultSet containing array of files. For each file, there is metadata including: name, size, created and modified dates, scan status and date, scan output message.
Move Files
Moves one or more files between storage prefixes, while additionally allowing the name to be modified
Method
GET
Endpoint
{baseUrl}/services/private/FTSWrapper/movefiles
Parameters
Common headers
Request
An array of files containing the current and new storage prefixes and file names, as shown below.
{"listOfFiles": [
	{"currentPath":
		{ "storagePrefix": "string",
			"fileName": "string"},
			"newPath": {
Response
HTTP 200, request succeeded;
HTTP 500, an error was encountered.
Delete Files
Deletes one more or files
Method
DELETE
Endpoint
{baseUrl}/services/private/FTSWrapper/deletefiles
Parameters
Common headers
Request
A JSON array of files to be deleted. One or more pairs of storagePrefix and filename elements can be specified within the array.
{"listOfFiles":
Response
A JSON array of each file deletion attempted and the result.
Request Upload PAR
Request PAR for uploading one or more files
Method
POST
Endpoint
{baseUrl}/services/private/FTSWrapper/upload
Parameters
Common headers
Request
A JSON array of files to be uploaded. One or more pairs of storagePrefix and filename elements can be specified within the array.
{ "listOfFiles":
Response
A parList containing an array containing elements corresponding to the request including the PAR accessUri and name of file.
Request Download PAR
Request PARs for downloading one or more files
Method
POST
Endpoint
{baseUrl}/services/private/FTSWrapper/download
Parameters
Common headers
Request
A JSON array of files to be downloaded. One or more pairs of storagePrefix and filenames can be specified within the array.
{ "listOfFiles":
Response
