F Appendix: AP CS Scheduling in JOS/POM
AP CS provides a default job schedule with a detailed list of jobs with pre-defined dependencies with RI and AIF schedules in RAP integration. The customer can easily customize their batch process by controlling the batch control files without changing the batch schedule. Each batch job in AP is connected to hooks in the batch control files that can be changed by customers. The AP job flow only contains daily and weekly jobs. Jobs scheduled daily are scheduled to run every day. Jobs scheduled to run weekly are scheduled to run only on Sunday by default.
The following table shows the list of jobs in the AP Schedule. Only jobs with Template configuration entries are pre-configured for the AP Template version. The rest of the jobs are placeholder jobs to allow changes to the schedule of the jobs or to add more jobs by changing the batch control file. Each AP job calls the same set names in the batch control file without _JOB in the name which in turn allows it to call the respective *hook jobs, so even if it is not linked to a batch set. The batch can be controlled without changing the job flow by adding or changing the hooks.
If AP CS is not the first planning application deployed in RAP and if another planning application such as MFP or RDF is already deployed, then set Primary to Load Common Data to false under the Planning Administration -> Batch Setup in show/hide, to avoid trying to load the common data again for shared planning applications through the JOS/POM schedule.
For more details about the implementation of JOS/POM, see the Oracle Retail Predictive Application Server Cloud Edition Implementation Guide. For more details about how to use JOS/POM to schedule and maintain the job flows, see the Oracle Retail JOS/POM User Guide.
AP Job Name Description/Comments Daily/Weekly Template Configuration
AP_PRE_EXP_START_JOB
Dummy Job, to specify the start of pre-batch exports.
Daily
AP_PRE_EXP_RDX_D_JOB
To schedule any daily data imports from RAP integration before the calc cycle.
Daily
AP_PRE_EXP_OBS_D_JOB
To schedule any daily data imports from Object Storage before the calc cycle.
Daily
Exports Standard Plans, if the Export Daily Plans Boolean is enabled.
AP_PRE_EXP_RDX_W_JOB
To schedule any weekly data imports from RAP integration before the calc cycle.
Weekly
Exports Plans to RI, if RDX is enabled.
AP_PRE_EXP_OBS_W_JOB
To schedule any weekly data imports from Object Storage before the calc cycle.
Weekly
Exports Standard Plans Weekly, if the Export Weekly Plans Boolean is enabled.
Also exports to Allocation if DRDVALLOCB is enabled.
AP_PRE_EXP_END_JOB
Dummy job to specify the end of pre-batch exports.
Daily
AP_COM_HIER_IMP_START_JOB
Dummy job to specify the start of a common hierarchies import.
Daily
AP_COM_HIER_IMP_RDX_D_JOB
To schedule any daily common hierarchy imports from RAP integration.
Daily
AP_COM_HIER_IMP_OBS_D_JOB
To schedule any daily common hierarchy imports from Object Storage.
Daily
AP_COM_HIER_IMP_RDX_W_JOB
To schedule any weekly common hierarchy imports from RAP integration.
Weekly
Imports hierarchies from RI, if RDX is enabled.
AP_COM_HIER_IMP_OBS_W_JOB
To schedule any weekly common hierarchy imports from Object Storage.
Weekly
Loads hierarchy files from Object Storage, if uploaded.
AP_COM_HIER_IMP_END_JOB
Dummy Job, to specify the end of a common hierarchies import.
Daily
AP_COM_DATA_IMP_START_JOB
Dummy job to specify the start of common data imports.
Daily
AP_COM_DATA_IMP_RDX_D_JOB
To schedule any daily common data imports from RAP integration.
Daily
AP_COM_DATA_IMP_OBS_D_JOB
To schedule any daily common data imports from Object Storage.
Daily
AP_COM_DATA_IMP_RDX_W_JOB
To schedule any weekly common data imports from RAP integration.
Weekly
Imports data files from RI, if RDX is enabled.
AP_COM_DATA_IMP_OBS_W_JOB
To schedule any weekly common data imports from Object Storage.
Weekly
Loads data files from Object Storage, if uploaded.
AP_COM_DATA_IMP_END_JOB
Dummy job to specify the end of common data imports.
Daily
AP_HIER_IMP_START_JOB
Dummy job to specify the start of application-specific hierarchies import.
Daily
AP_HIER_IMP_RDX_D_JOB
To schedule any daily application-specific hierarchy imports from RAP integration.
Daily
AP_HIER_IMP_OBS_D_JOB
To schedule any daily application-specific hierarchy imports from Object Storage.
Daily
AP_HIER_IMP_RDX_W_JOB
To schedule any weekly application-specific hierarchy imports from RAP integration.
Weekly
Imports application-specific hierarchies from RI, if RDX is enabled.
AP_HIER_IMP_OBS_W_JOB
To schedule any weekly application-specify hierarchy imports from Object Storage.
Weekly
Imports any application-specific hierarchies from Object Storage.
AP_HIER_IMP_END_JOB
Dummy job to specify the end of application-specific hierarchies import.
Daily
AP_PRE_DATA_IMP_START_JOB
Dummy job to specify the start of application-specific data imports before the calc cycle.
Daily
AP_PRE_DATA_IMP_RDX_D_JOB
To schedule any daily application-specific data imports from RAP integration before the calc cycle.
Daily
AP_PRE_DATA_IMP_OBS_D_JOB
To schedule any daily application-specific data imports from Object Storage before the calc cycle.
Daily
AP_PRE_DATA_IMP_RDX_W_JOB
To schedule any weekly application-specific data imports from RAP integration before the calc cycle.
Weekly
AP_PRE_DATA_IMP_OBS_W_JOB
To schedule any weekly application-specific data imports from Object Storage before the calc cycle
Weekly
AP_PRE_DATA_IMP_END_JOB
Dummy Job to specify the end of application-specific data imports before the calc cycle
Daily
AP_BATCH_AGG_START_JOB
Dummy job to specify the start of the Batch Aggregation Cycle.
Daily
AP_BATCH_AGG_D_JOB
To schedule any daily batch aggregation jobs.
Daily
Runs Daily Batch Calcs or Aggregations.
AP_BATCH_AGG_W_JOB
To schedule any weekly batch aggregation jobs.
Weekly
Runs Weekly Batch Calcs or Aggregations.
AP_BATCH_AGG_END_JOB
Dummy job to specify the end of the Batch Aggregation Cycle.
Daily
AP_POST_DATA_IMP_START_JOB
Dummy job to specify the start of application-specific data imports after the calc cycle.
Daily
AP_POST_DATA_IMP_RDX_D_JOB
To schedule any daily application-specific data imports from RAP integration after the calc cycle.
Daily
AP_POST_DATA_IMP_OBS_D_JOB
To schedule any daily application-specific data imports from Object Storage after the calc cycle.
Daily
AP_POST_DATA_IMP_RDX_W_JOB
To schedule any weekly application-specific data imports from RAP integration after the calc cycle.
Weekly
Imports data from, enabled Interfaces from AIF, if RDX is enabled.
AP_POST_DATA_IMP_OBS_W_JOB
To schedule any weekly application-specific data imports from Object Storage after the calc cycle.
Weekly
AP_POST_DATA_IMP_END_JOB
Dummy Job, to specify the end of application-specific data imports after the calc cycle.
Daily
AP_POST_EXP_START_JOB
Dummy job to specify the start of post-batch exports.
Daily
AP_POST_EXP_RDX_D_JOB
To schedule any daily data exports from RAP integration after the calc cycle.
Daily
AP_POST_EXP_OBS_D_JOB
To schedule any daily data exports from Object Storage after the calc cycle.
Daily
AP_POST_EXP_RDX_W_JOB
To schedule any weekly data export from RAP integration after the calc cycle.
Weekly
Exports data from, enabled Interfaces to AIF, if RDX is enabled.
AP_POST_EXP_OBS_W_JOB
To schedule any weekly data exports from Object Storage after the calc cycle.
Weekly
AP_POST_EXP_END_JOB
Dummy job to specify the end of post-batch exports.
Daily
AP_WB_BUILD_START_JOB
Dummy job to specify the start of workbook build/refresh jobs.
Daily
AP_WB_BUILD_D_JOB
To schedule any workbook build/refresh steps daily.
Daily
Runs daily scheduled workbook builds and refresh.
AP_WB_BUILD_W_JOB
To schedule any workbook build/refresh steps weekly.
Weekly
Runs weekly scheduled workbook builds and refresh.
AP_WB_BUILD_END_JOB
Dummy job to specify the end of workbook build/refresh jobs.
Daily
AP_ADHOC_XX_JOB
To schedule any adhoc jobs with the batch execution set name as a parameter. XX varies from 01 to 10. 10 Jobs available to schedule any adhoc steps with any set name as the parameter.
Adhoc
