A Appendix: Integration with MFP Cloud Service
Assortment Planning Cloud Service can be integrated with MFP Cloud Service to interface the Plan data. This appendix provides details about the integration.
APCS needs MFPCS data to use Merchandise Financial Planning data as a target to align with final assortments. If both MFPCS and APCS are co-deployed in the same environment and both are using the GA version, then all integrated MFPCS measures will be readily available in APCS. When plans are approved in MFPCS, it will be readily available in APCS. No separate batch or integration is needed to interface the MFP Plan data.
The following table shows the list of measures shared between MFPCS and APCS pre-configured applications. All the ML measures are at the Week/Sub-Class/Store level and the LP measures are at the Week/Department/Store level. ML measures are directly used in the AP planning process templates but LP (Location Plan) measures are used only in the batch process which spreads Warehouse data to the location level if the customer uses the option to spread using Location Plan from MFP instead of last year actuals.
MFP Cloud Service to Assortment Planning Cloud Service
MFP Measure MFPCS Label APCS Label File Name
mlcpeopc
ML Cp EOP C
MFP Loaded CP EOP C
mfp_mpcp.csv.ovr
mlcpeopr
ML Cp EOP R
MFP Loaded CP EOP R
mfp_mpcp.csv.ovr
mlcpeopu
ML Cp EOP U
MFP Loaded CP EOP U
mfp_mpcp.csv.ovr
mlcprcptc
ML Cp Receipts C
MFP Loaded CP Receipts C
mfp_mpcp.csv.ovr
mlcprcptr
ML Cp Receipts R
MFP Loaded CP Receipts R
mfp_mpcp.csv.ovr
mlcprcptu
ML Cp Receipts U
MFP Loaded CP Receipts U
mfp_mpcp.csv.ovr
mlcprtn1r
ML Cp Returns Reg+Promo R
MFP Loaded CP Returns Reg+Promo R
mfp_mpcp.csv.ovr
mlcprtn1u
ML Cp Returns Reg+Promo U
MFP Loaded CP Returns Reg+Promo U
mfp_mpcp.csv.ovr
mlcprtn2r
ML Cp Returns Clr R
MFP Loaded CP Returns Clear R
mfp_mpcp.csv.ovr
mlcprtn2u
ML Cp Returns Clr U
MFP Loaded CP Returns Clear U
mfp_mpcp.csv.ovr
mlcpsls1r
ML Cp Sales Reg+Promo R
MFP Loaded CP Sales Reg+Promo R
mfp_mpcp.csv.ovr
mlcpsls1u
ML Cp Sales Reg+Promo U
MFP Loaded CP Sales Reg+Promo U
mfp_mpcp.csv.ovr
mlcpsls2r
ML Cp Sales Clr R
MFP Loaded CP Sales Clr R
mfp_mpcp.csv.ovr
mlcpsls2u
ML Cp Sales Clr U
MFP Loaded CP Sales Clr U
mfp_mpcp.csv.ovr
mlcpslsc
ML Cp Sales C
MFP Loaded CP Sales Reg+Promo C
mfp_mpcp.csv.ovr
mlwpooadjc
ML Wp On Order Adj C
MFP Loaded WP On Order Adj C
mfp_otb.csv.rpl
mlwpooadjr
ML Wp On Order Adj R
MFP Loaded WP On Order Adj R
mfp_otb.csv.rpl
mlwpooadju
ML Wp On Order Adj U
MFP Loaded WP On Order Adj U
mfp_otb.csv.rpl
mlwpotbc
ML Wp OTB C
MFP Loaded WP OTB C
mfp_otb.csv.rpl
mlwpotbr
ML Wp OTB R
MFP Loaded WP OTB R
mfp_otb.csv.rpl
mlwpotbu
ML Wp OTB U
MFP Loaded WP OTB U
mfp_otb.csv.rpl
lplaeopc
Ap EOP C
LP AP EOP C
mfp_lpap.csv.ovr
lplapeopr
Ap EOP R
LP AP EOP R
mfp_lpap.csv.ovr
lplapeopu
Ap EOP U
LP AP EOP U
mfp_lpap.csv.ovr
lplaprcptc
Ap Receipts C
LP AP Receipts C
mfp_lpap.csv.ovr
lplaprcptr
Ap Receipts R
LP AP Receipts R
mfp_lpap.csv.ovr
lplaprcptu
Ap Receipts U
LP AP Receipts U
mfp_lpap.csv.ovr
lplaprtnr
Ap Returns R
LP AP Returns R
mfp_lpap.csv.ovr
lplaprtnu
Ap Returns U
LP AP Returns U
mfp_lpap.csv.ovr
lplaslsc
Ap Sales C
LP AP Sales C
mfp_lpap.csv.ovr
lplaslsr
Ap Sales R
LP AP Sales R
mfp_lpap.csv.ovr
lplaslsu
Ap Sales U
LP AP Sales U
mfp_lpap.csv.ovr
If the customer is using their own customized MFP, they can provide the MFP Plan data in csv file format with the measures grouped by File Name as defined in the above table interface with headers as the measure names.
