Import Product Images (imp_img)
This task is used to import product image details that are coming from AI Foundation through RAP integration. It runs all the required interfaces to pull the image name and image address details from RAP. The list of measure mappings details can be found in the Import Foundation and Transactional Data from Retail Insights section in the RAP Integration chapter of the Oracle Retail Assortment Planning Cloud Service Implementation Guide. If the Aggregate Image Boolean is enabled for different levels in Planning Admin -> Batch Setup, the batch process will also aggregate the loaded Item Level images using the mode_pop agg type to show the images for Style-Color, Style, and Sub-class levels for which the Booleans are enabled. The customer can also disable Image aggregation and directly load different images for those levels by loading the corresponding Image URLs using a flat file and using the same task.
This task automatically runs as part of the weekly batch, if Batch Uses RDX is set to true in the Planning Admin -> Batch Setup view from show/hide.
