Load MFP Data (batch_mfp)
This task is used to load the MFP interface files if the customer is using their own MFP version. They can upload the MFP interface files in the required format into Object Storage and run this task to load the MFP data.
For details about the list of measure files and about integration with MFP, see the Oracle Retail Assortment Planning Cloud Service Implementation Guide.
This task automatically runs as part of the weekly batch, if Enable MFP CS Integration is set to true in the Planning Admin -> Batch Setup view from show/hide.
