Run Batch Measure Load Group
This task is used to load a predefined set of measures grouped as a measure set in the batch control file batch_loadmeas_list.txt. These set of measures can be loaded together. Actuals Data is a named set of load measures in the batch control file. If the Administrator decides to load the measure set for Actuals Data, the Administrator needs to load data for measures which includes measures such as Ty Sales Clr R and TY Sales Clr U. All required data files must be uploaded to Object Storage. If there is no file present to load a particular measure in that measure set, it will be logged as not found and skipped.
This process will only load the data into those measures and will not run any subsequent calculations after it. The Administrator may need to schedule the necessary Run Batch Calc Group task after scheduling this task in order to process the loaded data.
The Predefined Measure Load Options in APCS are listed below:
Actuals Data (load_act) - To load all the measures containing actual data as needed such as Sales, Inventory, Receipt, Shrink, and so on.
On Order Data (load_oo) - To load only On Order data files.
Admin Data (load_adm) - To load planning administration level data such as Week Mapping, Clustering Weights, and so on.
Forecast Data (load_fcst) - To load Forecast Data.
MFP Data (load_mfp) - To load MFP Data.
Week Mapping (load_lymap) - To load the Week Mapping file.
Placeholder Rename (load_phrn) - To load the Placeholder Rename files.
- Image URL Files (load_img) - To load all the Image URL files.
For details about the list of measure files that are loaded for different measure sets and file format and source information, see the Oracle Retail Assortment Planning Cloud Service Implementation Guide.
