Special Expressions and Procedures Used in APCS Configuration
This section contains details about the special expressions that are not standard RPAS expressions/procedures but are used in the APCS configuration.
AttributesPickListExpr - Attribute Picklist Expression
This procedure is used to determine a picklist of values from a base string measure along the positions of the specified hierarchy. It also takes in a Filter Boolean as input to control which intersections are to be used to pick data for the picklist.
Syntax:
OUTMEAS <- AttributesPickListExpr(FILTERMEAS, INPUTMEAS, HIER, OUTFORMAT)
Example:
ADHDLikePoCT <- AttributesPickListExpr(ADHDLikePoCB,ADHDLikePoCL, "LOC", "0")
Expression Parameters:
The following table shows the parameter details for the expression.
Parameter Name Parameter Type Data Type Description
OUTMEAS
Output
String
Output Picklist Measure which will be a string value.
INPUTMEAS
Input
String
Input String Measure containing the picklist values stored along a hierarchy.
FILTERMEAS
Input
Boolean
Boolean measure with the same intersection of OUTMEAS. It should be set to true for the intersections picklist that needs to be created.
HIER
Input
String
Hierarchy Name specified as a String constant along which the picklist values need to be used. This hierarchy should be present in INPUTMEAS.
OUTFORMAT
Input
String
Output format with valid values "0" or "1". Using "0" will create a picklist using position names as picklist internal names and labels as attribute values. "1" will create a picklist using position values as name and labels for the picklist.
BopEopCalcExpr - Inventory Roll Calculation Expression
All planning applications typically need to create some batch rules to do inventory roll operations for all their actualized positions. Inventory roll calculations involve Beginning Inventory (BOP) and Ending Inventory (EOP) metrics, where BOP is calculated as lag of EOP (previous periods EOP) and EOP will be calculated from that period BOP plus additional metrics (Receipts, Sales, and so on). RPAS supports the use of the lag function to calculate BOP and creation of a separate expression to calculate EOP.
They normally run as cyclic rules in a batch rule group. Problem is this dual cyclic expression is highly performance intensive if it needs to roll inventory at the item/sku/store level. This is an optimized procedure to do inventory rollup calculations as a single expression instead of using them as cyclic expressions. This procedure can be used only in batch mode and should not be used in workbook calculation cycle rule groups.
Syntax:
EOP:<MEAS>,BOP:<MEAS> <- BopEopCalcExpr(TODAYINDEX:<MEAS>, INCEOP:<MEAS>, ACTEOP:<MEAS>, TSMASK:<MEAS>, INITIALBOP:<MEAS>)
Example:
EOP:ISWPEOPU,BOP:ISWPBOPU <- BopEopCalcExpr(TODAYINDEX:DRDVUnElapI, INCEOP:ISDVEOPU, ACTEOP:DRDVEOPU, TSMASK:DRDVEOPB, INITIALBOP:DRDVBOSU)
The above expression is equivalent to running the following two expressions in batch as a cyclic rule group:
ISWPBOPU = if (DRDVEOPB, if (current == first, DRDVBOSU, lag(ISWPEOPU)), ignore)
ISWPEOPU = if (DRDVEOPB, if (DRDVUnElapB, ISWPBOPU + ISDVEOPU, DRTYEOPU), ignore)
EOP
Output
Real
Calculated Ending Inventory value measure.
BOP
Output
Real
Beginning Inventory value measure, same intersection as EOPMEAS.
ACTEOP
Input
Real
Actual Ending Inventory for Elapsed Periods. Same Intersection as BOP and EOP.
INCEOP
Input
Real
Incremental Inventory value for UnElapsed Periods. Same intersection as BOP and EOP.
TODAYINDEX
Input
Integer
Index of Current RPAS Today period. Periods above this will be copied with actual EOP, periods after this will be calculated with BOP and Incremental EOP. Base Intersection higher or equal to BOP/EOP but should not have the calendar dimension.
TSMASK
Input
Boolean
Intersections to which inventory roll calculations need to be performed. Same intersection as BOP and EOP but without calendar dimension.
INITIALBOP
Input
Real
First Period Beginning Inventory value measure. Same Intersection of BOP and EOP but without the calendar dimension.
ClusterExpr - Cluster Expression
This procedure is used to define a dynamic cluster based on input parameters.
Syntax:
POINTMEMBERSHIP: <MEAS>, POINTMEMBERSHIPSTR: <MEAS>, CENTROID: <MEAS> <- ClusterExpr(MEASURE: <MEAS>, METHOD: <STRING>, NUMCLUSTERS: <MEAS>, CLUSTERHIER: <HIER>, BYGROUPDIMS: <DIMENSION>)
Example:
POINTMEMBERSHIP: SCDVBangGrpID, POINTMEMBERSHIPSTR: SCDVBangGrpT, CENTROID: SCDVBangGrpX <- ClusterExpr(MEASURE: SCDVCmbIdxV, METHOD: "BANG", NUMCLUSTERS: SCHDMaxPrfGrpU, CLUSTERHIER: "LOC", BYGROUPDIMS: "CHNL")
POINTMEMBERSHIP
Output
Integer
Output Cluster Group Id at Location level.
POINTMEMBERSHIPSTR
Output
String
Output Cluster Group String at Location level.
CENTROID
Output
Real
Output Centroid value at Aggregate level.
MEASURE
Input
Real
Input Score measure at Location level.
METHOD
Input
String
String constant with valid value, "BANG" for Bang Algorithm to use.
NUMCLUSTERS
Input
Integer
Number of Clusters to Create at Aggregate of Location level.
CLUSTERHIER
Input
String
String constant with hierarchy name of Location hierarchy for which cluster is created.
BYGROUPDIMS
Input
String
String constant of dimension name in Location hierarchy at Aggregate level.
CMNewItemSimilarityV2Expr - Item Similarity Expression
This procedure is a wrapper procedure used for calling AI Foundation functions which calculate the Item Similarity Scores based on Product Attributes and Product Attribute Weights. This similarity score can be internally calculated and used in Demand Transference procedures as input to determine the Demand Transference across similar items. It is also used in Assortment Improvement Procedures using Demand Transference. This procedure is not currently used in the current AP template version but examples are kept for customers using the non-template version.
Syntax:
SIM_OUT <- CMNewItemSimilarityV2Expr(SIM_IN, PROD_ATTR, ATTR_WGT, DT_MODE, FUNC_FIT, SAME_ITEM_MAP, VALID_ATTR, SIM_MODE)
Example:
BWHDSimOutVp <- CMNewItemSimilarityV2Expr(BWHDSimInV, ADDVPrdAttT, BWHDAttrWgtV, DRDVDTModeX, BWHDFuncFitB, DRDVSkupMapB, BWHDPrdAttB, DRDVSimModeV)
SIM_OUT
Output
Real
Similarity score across LHS and RHS Items at Item/Cluster/RHS Item level.
SIM_IN
Input
Real
It is needed only if a different Similarity Mode other than 0 is used. For default Similarity Mode 0, this can be initialized to 0 which calculates similarity for all items.
PROD_ATTR
Input
String
Product Attribute values at Item/Product Attribute level.
ATTR_WGT
Input
Real
Attribute Weight at Item/Attribute level.
DT_MODE
Input
Integer
Demand Transference Mode to calculate the similarity scores, value of 4 is for calculating Bi-Directional Similarity Score, 3 for One Directional Score.
FUNC_FIT
Input
Boolean
Functional Fit Boolean at Sub-Class/Product Attribute level.
SAME_ITEM_MAP
Input
Boolean
Same Item mapping across LHS-RHS Items at LHS-RHS Item level.
VALID_ATTR
Input
Boolean
Product Attribute Eligibility at Sub-Class/Attribute level.
SIM_MODE
Input
Real
Similarity mode at sub-class level with default value as 0 for similarity values calculating for all items.
CMDemandSignTranV2Expr - Demand Transference Expression
This procedure is a wrapper procedure used for calling AI Foundation functions which in turn calculate the Demand Transferences and Substitutable Sales Units. It also calculates the significant similar items and substitutable sales percentage against each similar item based on the similarity scores. It internally calculates the similarity scores using the attribute inputs and uses it to calculate the Demand transference outputs. This procedure is not currently used in the current AP template version but examples are kept for customers using the non-template version.
Syntax:
DT_SIG_SKU_COUNT, DT_SIG_SUB_PCT, DT_SALES, DT_SUB_SALES <- CMDemandSignTranV2Expr(DT_MASK, SIM_OUT, ITEM_KAD, INPUT_SALES, SAME_ITEM_MAP, ASSORT_ELASTICITY, DT_CUTOFF, DT_GUARD, PROD_ATTR, ATTR_WGT, SIM_MODE, FUNC_FIT, VALID_ATTR)
Example:
BWHDDTSigSkuV, BWHDDTSigSkuVp, BWHDDTSlsU, BWHDDTSubSlsU <- CMDemandSignTranV2Expr(BWHDRunMaskB, BWH1SimOutVp, BWHDDTKADX, BWHDDTROSU, DRDVSkupMapB, BWHDAssrtElasV, DRDVDTCutOffVp, DRDVDTGuardB, ADDVPrdAttT, BWHDAttrWgtV, DRDVSimModeV, BWHDFuncFitB, BWHDPrdAttB)
DT_SIG_SKU_COUNT
Output
Integer
Significant Substitutable Items count at Item/Cluster level.
DT_SIG_SUB_PCT
Output
Real
Significant Sku Substitutable Percentage at Item/Cluster/RHS Item level.
DT_SALES
Output
Real
Demand Transference ROS/Sales at Item/Cluster level (At same level of input ROS).
DT_SUB_SALES
Output
Real
Substitutable ROS/Sales at Item/Cluster level.
DT_MASK
Input
Boolean
Mask at Sub-class/Cluster level for which DT needs to be calculated.
SIM_OUT
Input
Real
It is needed only if different Similarity Mode other than 0 is used. For default Similarity Mode 0, this can be initialized to 0 procedure internally calculates similarity for all items.
ITEM_KAD
Input
Integer
Item Keep/Add/Drop Status with valid values as 1 for Add, 2 for Keep, and 3 for Drop Status of Items at Item/Cluster level.
INPUT_SALES
Input
Real
Initial Forecasted/Historical Sales or Rate of Sales at Item/Cluster level.
SAME_ITEM_MAP
Input
Boolean
ASSORT_ELASTICITY
Input
Real
Assortment Elasticity at Sub-Class/Cluster level.
DT_CUTOFF
Input
Real
DT Cut-Off % at Sub-Class/Cluster level.
DT_GUARD
Input
Real
DT Guard Boolean at Sub-Class/Cluster level.
PROD_ATTR
Input
String
ATTR_WGT
Input
Real
SIM_MODE
Input
Real
FUNC_FIT
Input
Boolean
VALID_ATTR
Input
Boolean
CMAssortImprovementV2Expr - Assortment Improvement using DT Expression
This procedure is a wrapper procedure used for calling AI Foundation functions which in turn use the Demand Transferences and suggest the Improved Assortments after applying Demand Transferences based on the input assortment improvement parameters. This procedure is not currently used in the current AP template version but examples are kept for customers using the non-template version.
Syntax:
OPT_ASSORT, OPT_SALES <- CMAssortImprovementV2Expr(DT_MASK, INIT_SALES, SAME_ITEM_MAP, SIM_OUT, NEW_ITEM, INIT_ASSORT, IMPROVE_METRIC, ELIGIBLE_ITEM, IMPROVE_COUNT, MIN_TO_KEEP, OPT_MODE, ASSORT_ELASTICITY, ITEM_MANDATORY, OPT_TARGET, PROD_ATTR, ATTR_WGT, SIM_MODE, FUNC_FIT, VALID_ATTR)
Example:
BWHDDTImprAsrtB, BWHDDTImprAsrtU <- CMAssortImprovementV2Expr(BWHDRunMaskB, BWHDDTInitAsrtU, DRDVSkupMapB, BWH1SimOutVp, BWHDDTNewB, BWHDDTInitAsrtB, BWHDDTMetricImprV, BWHDDTEligB, BWHDDTImprAsrtV, BWHDMinKeepVp, BWHDDTOptModeV, BWHDAssrtElasV, BWHDDTMandB, BWHDDTOptTgtV, ADDVPrdAttT, BWHDAttrWgtV, DRDVSimModeV, BWHDFuncFitB, BWHDPrdAttB)
OPT_ASSORT
Output
Boolean
Optimized Assortment after adding/removing items based on input parameters at Item/Cluster level.
OPT_SALES
Output
Real
Optimized Sales/ROS by calculating Improved Assortment after applying Demand Transference at Item/Cluster level.
DT_MASK
Input
Boolean
Mask at Sub-class/Cluster level for which Optimized Assortment needs to be calculated.
INIT_SALES
Input
Real
Initial Forecasted or Historical Sales or ROS at Item/Cluster level for all eligible items. It needs Sales/ROS for both historical and new items.
SAME_ITEM_MAP
Input
Boolean
SIM_OUT
Input
Real
NEW_ITEM
Input
Boolean
New Items within the Assortment at Item/Cluster level.
INIT_ASSORT
Input
Boolean
Initial Planned Assortment before running Assortment Improvement at Item/Cluster level.
IMPROVE_METRIC
Input
Real
Metric to Improve, 1.0 for Sales Units (at same level of input ROS/Sales). For Sales Retail or Gross Margin, multiply it with Sales Price or Price Margin at Item/Cluster level.
ELIGIBLE_ITEM
Input
Boolean
All Eligible Items that can be included into the assortment for improvement at Item/Cluster level.
IMPROVE_COUNT
Input
Integer
Number of Items to be added, removed, or swapped from the assortment at Sub-Class/Cluster level.
MIN_TO_KEEP
Input
Real
Minimum Percentage of Initial Assortment to Keep during Assortment Improvement at Sub-Class/Cluster level.
OPT_MODE
Input
Integer
Optimization Mode with values 1 for Add with Swap, 2 for Drop with Swap, 3 for Swap, 4 for Add, and 5 for Remove at Sub-Class/Cluster level.
ASSORT_ELASTICITY
Input
Real
ITEM_MANDATORY
Input
Boolean
Mandatory Items to Keep after running Assortment Improvement at Item/Cluster level.
OPT_TARGET
Input
Real
Target to Achieve by Swapping assortments at Sub-Class/Cluster level.
PROD_ATTR
Input
String
ATTR_WGT
Input
Real
SIM_MODE
Input
Real
FUNC_FIT
Input
Boolean
VALID_ATTR
Input
Boolean
