Generate Placeholder View
Placeholder creation stands out as a unique and critical task in the Assortment Planning process. Unlike other applications, Assortment Planning requires the creation of new products at least 6-9 months ahead of the season, enabling Assortment Analysts to strategize and share plans with systems for commitments and product development.
The Generate Placeholder feature simplifies this task by leveraging a smart algorithm to automate placeholder creation. With just a few clicks, you can efficiently create placeholders in bulk, ensuring efficiency and accuracy in aligning with the approved strategy.
This streamlined process not only saves time but also ensures that the assortment is ready to run well in advance, setting the stage for a seamless transition from planning to procurement.
