Special Expressions and Procedures Used in APCS Configuration
This section contains details about the special expressions that are not standard RPAS expressions/procedures but are used in the APCS configuration.
AttributesPickListExpr - Attribute Picklist Expression
This procedure is used to determine a picklist of values from a base string measure along the positions of the specified hierarchy. It also takes in a Filter Boolean as input to control which intersections are to be used to pick data for the picklist.
Syntax:
OUTMEAS <- AttributesPickListExpr(FILTERMEAS, INPUTMEAS, HIER, OUTFORMAT)
Example:
ADHDLikePoCT <- AttributesPickListExpr(ADHDLikePoCB,ADHDLikePoCL, "LOC", "0")
Expression Parameters:
The following table shows the parameter details for the expression.
| Parameter Name | Parameter Type | Data Type | Description |
OUTMEAS |
Output |
String |
Output Picklist Measure which will be a string value. |
INPUTMEAS |
Input |
String |
Input String Measure containing the picklist values stored along a hierarchy. |
FILTERMEAS |
Input |
Boolean |
Boolean measure with the same intersection of OUTMEAS. It should be set to true for the intersections picklist that needs to be created. |
HIER |
Input |
String |
Hierarchy Name specified as a String constant along which the picklist values need to be used. This hierarchy should be present in INPUTMEAS. |
OUTFORMAT |
Input |
String |
Output format with valid values "0" or "1". Using "0" will create a picklist using position names as picklist internal names and labels as attribute values. "1" will create a picklist using position values as name and labels for the picklist. |
BopEopCalcExpr - Inventory Roll Calculation Expression
All planning applications typically need to create some batch rules to do inventory roll operations for all their actualized positions. Inventory roll calculations involve Beginning Inventory (BOP) and Ending Inventory (EOP) metrics, where BOP is calculated as lag of EOP (previous periods EOP) and EOP will be calculated from that period BOP plus additional metrics (Receipts, Sales, and so on). RPAS supports the use of the lag function to calculate BOP and creation of a separate expression to calculate EOP.
They normally run as cyclic rules in a batch rule group. Problem is this dual cyclic expression is highly performance intensive if it needs to roll inventory at the item/sku/store level. This is an optimized procedure to do inventory rollup calculations as a single expression instead of using them as cyclic expressions. This procedure can be used only in batch mode and should not be used in workbook calculation cycle rule groups.
Syntax:
EOP:<MEAS>,BOP:<MEAS> <- BopEopCalcExpr(TODAYINDEX:<MEAS>, INCEOP:<MEAS>, ACTEOP:<MEAS>, TSMASK:<MEAS>, INITIALBOP:<MEAS>)
Example:
EOP:ISWPEOPU,BOP:ISWPBOPU <- BopEopCalcExpr(TODAYINDEX:DRDVUnElapI, INCEOP:ISDVEOPU, ACTEOP:DRDVEOPU, TSMASK:DRDVEOPB, INITIALBOP:DRDVBOSU)
The above expression is equivalent to running the following two expressions in batch as a cyclic rule group:
ISWPBOPU = if (DRDVEOPB, if (current == first, DRDVBOSU, lag(ISWPEOPU)), ignore)
ISWPEOPU = if (DRDVEOPB, if (DRDVUnElapB, ISWPBOPU + ISDVEOPU, DRTYEOPU), ignore)
EOP |
Output |
Real |
Calculated Ending Inventory value measure. |
BOP |
Output |
Real |
Beginning Inventory value measure, same intersection as EOPMEAS. |
ACTEOP |
Input |
Real |
Actual Ending Inventory for Elapsed Periods. Same Intersection as BOP and EOP. |
INCEOP |
Input |
Real |
Incremental Inventory value for UnElapsed Periods. Same intersection as BOP and EOP. |
TODAYINDEX |
Input |
Integer |
Index of Current RPAS Today period. Periods above this will be copied with actual EOP, periods after this will be calculated with BOP and Incremental EOP. Base Intersection higher or equal to BOP/EOP but should not have the calendar dimension. |
TSMASK |
Input |
Boolean |
Intersections to which inventory roll calculations need to be performed. Same intersection as BOP and EOP but without calendar dimension. |
INITIALBOP |
Input |
Real |
First Period Beginning Inventory value measure. Same Intersection of BOP and EOP but without the calendar dimension. |
ClusterExpr - Cluster Expression
This procedure is used to define a dynamic cluster based on input parameters.
Syntax:
POINTMEMBERSHIP: <MEAS>, POINTMEMBERSHIPSTR: <MEAS>, CENTROID: <MEAS> <- ClusterExpr(MEASURE: <MEAS>, METHOD: <STRING>, NUMCLUSTERS: <MEAS>, CLUSTERHIER: <HIER>, BYGROUPDIMS: <DIMENSION>)
Example:
POINTMEMBERSHIP: SCDVBangGrpID, POINTMEMBERSHIPSTR: SCDVBangGrpT, CENTROID: SCDVBangGrpX <- ClusterExpr(MEASURE: SCDVCmbIdxV, METHOD: "BANG", NUMCLUSTERS: SCHDMaxPrfGrpU, CLUSTERHIER: "LOC", BYGROUPDIMS: "CHNL")
POINTMEMBERSHIP |
Output |
Integer |
Output Cluster Group Id at Location level. |
POINTMEMBERSHIPSTR |
Output |
String |
Output Cluster Group String at Location level. |
CENTROID |
Output |
Real |
Output Centroid value at Aggregate level. |
MEASURE |
Input |
Real |
Input Score measure at Location level. |
METHOD |
Input |
String |
String constant with valid value, "BANG" for Bang Algorithm to use. |
NUMCLUSTERS |
Input |
Integer |
Number of Clusters to Create at Aggregate of Location level. |
CLUSTERHIER |
Input |
String |
String constant with hierarchy name of Location hierarchy for which cluster is created. |
BYGROUPDIMS |
Input |
String |
String constant of dimension name in Location hierarchy at Aggregate level. |
CMNewItemSimilarityV2Expr - Item Similarity Expression
This procedure is a wrapper procedure used for calling AI Foundation functions which calculate the Item Similarity Scores based on Product Attributes and Product Attribute Weights. This similarity score can be internally calculated and used in Demand Transference procedures as input to determine the Demand Transference across similar items. It is also used in Assortment Improvement Procedures using Demand Transference. This procedure is not currently used in the current AP template version but examples are kept for customers using the non-template version.
Syntax:
SIM_OUT <- CMNewItemSimilarityV2Expr(SIM_IN, PROD_ATTR, ATTR_WGT, DT_MODE, FUNC_FIT, SAME_ITEM_MAP, VALID_ATTR, SIM_MODE)
Example:
BWHDSimOutVp <- CMNewItemSimilarityV2Expr(BWHDSimInV, ADDVPrdAttT, BWHDAttrWgtV, DRDVDTModeX, BWHDFuncFitB, DRDVSkupMapB, BWHDPrdAttB, DRDVSimModeV)
SIM_OUT |
Output |
Real |
Similarity score across LHS and RHS Items at Item/Cluster/RHS Item level. |
SIM_IN |
Input |
Real |
It is needed only if a different Similarity Mode other than 0 is used. For default Similarity Mode 0, this can be initialized to 0 which calculates similarity for all items. |
PROD_ATTR |
Input |
String |
Product Attribute values at Item/Product Attribute level. |
ATTR_WGT |
Input |
Real |
Attribute Weight at Item/Attribute level. |
DT_MODE |
Input |
Integer |
Demand Transference Mode to calculate the similarity scores, value of 4 is for calculating Bi-Directional Similarity Score, 3 for One Directional Score. |
FUNC_FIT |
Input |
Boolean |
Functional Fit Boolean at Sub-Class/Product Attribute level. |
SAME_ITEM_MAP |
Input |
Boolean |
Same Item mapping across LHS-RHS Items at LHS-RHS Item level. |
VALID_ATTR |
Input |
Boolean |
Product Attribute Eligibility at Sub-Class/Attribute level. |
SIM_MODE |
Input |
Real |
Similarity mode at sub-class level with default value as 0 for similarity values calculating for all items. |
CMDemandSignTranV2Expr - Demand Transference Expression
This procedure is a wrapper procedure used for calling AI Foundation functions which in turn calculate the Demand Transferences and Substitutable Sales Units. It also calculates the significant similar items and substitutable sales percentage against each similar item based on the similarity scores. It internally calculates the similarity scores using the attribute inputs and uses it to calculate the Demand transference outputs. This procedure is not currently used in the current AP template version but examples are kept for customers using the non-template version.
Syntax:
DT_SIG_SKU_COUNT, DT_SIG_SUB_PCT, DT_SALES, DT_SUB_SALES <- CMDemandSignTranV2Expr(DT_MASK, SIM_OUT, ITEM_KAD, INPUT_SALES, SAME_ITEM_MAP, ASSORT_ELASTICITY, DT_CUTOFF, DT_GUARD, PROD_ATTR, ATTR_WGT, SIM_MODE, FUNC_FIT, VALID_ATTR)
Example:
BWHDDTSigSkuV, BWHDDTSigSkuVp, BWHDDTSlsU, BWHDDTSubSlsU <- CMDemandSignTranV2Expr(BWHDRunMaskB, BWH1SimOutVp, BWHDDTKADX, BWHDDTROSU, DRDVSkupMapB, BWHDAssrtElasV, DRDVDTCutOffVp, DRDVDTGuardB, ADDVPrdAttT, BWHDAttrWgtV, DRDVSimModeV, BWHDFuncFitB, BWHDPrdAttB)
DT_SIG_SKU_COUNT |
Output |
Integer |
Significant Substitutable Items count at Item/Cluster level. |
DT_SIG_SUB_PCT |
Output |
Real |
Significant Sku Substitutable Percentage at Item/Cluster/RHS Item level. |
DT_SALES |
Output |
Real |
Demand Transference ROS/Sales at Item/Cluster level (At same level of input ROS). |
DT_SUB_SALES |
Output |
Real |
Substitutable ROS/Sales at Item/Cluster level. |
DT_MASK |
Input |
Boolean |
Mask at Sub-class/Cluster level for which DT needs to be calculated. |
SIM_OUT |
Input |
Real |
It is needed only if different Similarity Mode other than 0 is used. For default Similarity Mode 0, this can be initialized to 0 procedure internally calculates similarity for all items. |
ITEM_KAD |
Input |
Integer |
Item Keep/Add/Drop Status with valid values as 1 for Add, 2 for Keep, and 3 for Drop Status of Items at Item/Cluster level. |
INPUT_SALES |
Input |
Real |
Initial Forecasted/Historical Sales or Rate of Sales at Item/Cluster level. |
SAME_ITEM_MAP |
Input |
Boolean |
ASSORT_ELASTICITY |
Input |
Real |
Assortment Elasticity at Sub-Class/Cluster level. |
DT_CUTOFF |
Input |
Real |
DT Cut-Off % at Sub-Class/Cluster level. |
DT_GUARD |
Input |
Real |
DT Guard Boolean at Sub-Class/Cluster level. |
PROD_ATTR |
Input |
String |
ATTR_WGT |
Input |
Real |
SIM_MODE |
Input |
Real |
FUNC_FIT |
Input |
Boolean |
VALID_ATTR |
Input |
Boolean |
CMAssortImprovementV2Expr - Assortment Improvement using DT Expression
This procedure is a wrapper procedure used for calling AI Foundation functions which in turn use the Demand Transferences and suggest the Improved Assortments after applying Demand Transferences based on the input assortment improvement parameters. This procedure is not currently used in the current AP template version but examples are kept for customers using the non-template version.
Syntax:
OPT_ASSORT, OPT_SALES <- CMAssortImprovementV2Expr(DT_MASK, INIT_SALES, SAME_ITEM_MAP, SIM_OUT, NEW_ITEM, INIT_ASSORT, IMPROVE_METRIC, ELIGIBLE_ITEM, IMPROVE_COUNT, MIN_TO_KEEP, OPT_MODE, ASSORT_ELASTICITY, ITEM_MANDATORY, OPT_TARGET, PROD_ATTR, ATTR_WGT, SIM_MODE, FUNC_FIT, VALID_ATTR)
Example:
BWHDDTImprAsrtB, BWHDDTImprAsrtU <- CMAssortImprovementV2Expr(BWHDRunMaskB, BWHDDTInitAsrtU, DRDVSkupMapB, BWH1SimOutVp, BWHDDTNewB, BWHDDTInitAsrtB, BWHDDTMetricImprV, BWHDDTEligB, BWHDDTImprAsrtV, BWHDMinKeepVp, BWHDDTOptModeV, BWHDAssrtElasV, BWHDDTMandB, BWHDDTOptTgtV, ADDVPrdAttT, BWHDAttrWgtV, DRDVSimModeV, BWHDFuncFitB, BWHDPrdAttB)
OPT_ASSORT |
Output |
Boolean |
Optimized Assortment after adding/removing items based on input parameters at Item/Cluster level. |
OPT_SALES |
Output |
Real |
Optimized Sales/ROS by calculating Improved Assortment after applying Demand Transference at Item/Cluster level. |
DT_MASK |
Input |
Boolean |
Mask at Sub-class/Cluster level for which Optimized Assortment needs to be calculated. |
INIT_SALES |
Input |
Real |
Initial Forecasted or Historical Sales or ROS at Item/Cluster level for all eligible items. It needs Sales/ROS for both historical and new items. |
SAME_ITEM_MAP |
Input |
Boolean |
SIM_OUT |
Input |
Real |
NEW_ITEM |
Input |
Boolean |
New Items within the Assortment at Item/Cluster level. |
INIT_ASSORT |
Input |
Boolean |
Initial Planned Assortment before running Assortment Improvement at Item/Cluster level. |
IMPROVE_METRIC |
Input |
Real |
Metric to Improve, 1.0 for Sales Units (at same level of input ROS/Sales). For Sales Retail or Gross Margin, multiply it with Sales Price or Price Margin at Item/Cluster level. |
ELIGIBLE_ITEM |
Input |
Boolean |
All Eligible Items that can be included into the assortment for improvement at Item/Cluster level. |
IMPROVE_COUNT |
Input |
Integer |
Number of Items to be added, removed, or swapped from the assortment at Sub-Class/Cluster level. |
MIN_TO_KEEP |
Input |
Real |
Minimum Percentage of Initial Assortment to Keep during Assortment Improvement at Sub-Class/Cluster level. |
OPT_MODE |
Input |
Integer |
Optimization Mode with values 1 for Add with Swap, 2 for Drop with Swap, 3 for Swap, 4 for Add, and 5 for Remove at Sub-Class/Cluster level. |
ASSORT_ELASTICITY |
Input |
Real |
ITEM_MANDATORY |
Input |
Boolean |
Mandatory Items to Keep after running Assortment Improvement at Item/Cluster level. |
OPT_TARGET |
Input |
Real |
Target to Achieve by Swapping assortments at Sub-Class/Cluster level. |
PROD_ATTR |
Input |
String |
ATTR_WGT |
Input |
Real |
SIM_MODE |
Input |
Real |
FUNC_FIT |
Input |
Boolean |
VALID_ATTR |
Input |
Boolean |
