4 Extension
This section lists some common extension patterns that can be implemented in RDS.
  • Import/export data using the Autonomous Database DBMS_CLOUD package
  • Import/export data using the APEX SQL Worksheet
  • Write a query that joins custom data and replicated data
  • Create a custom ORDS REST endpoint
  • Integrate an APEX application with a custom ORDS REST endpoint
  • Integrate an APEX application with a REST endpoint from a retail application
