Base URL
The base URL described below differs for production and non-production environments (NPE). A production environment host will begin with home.retail. A non-production environment host will begin with home-npe.retail. You should notice the difference in your Oracle Retail Home endpoint. All examples below assume a production environment.
The base URL of the Credential Exchange Service (CES) can be discovered from your Oracle Retail Home endpoint. If you do not know your Oracle Retail Home endpoint, contact your administrator.
The Oracle Retail Home endpoint has the following form:
https://home.retail.<region>.ocs.oraclecloud.com/<sub-namespace-name>
The sub-namespace-name can be further decomposed into:
rgbu-common-<customerid>-<env>-rh
You can extract region, customerid, and env from your Oracle Retail Home URL. The host port of the base URL is 443. The base URL for the CES is: https://home.retail.<region>.ocs.oraclecloud.com:443/rgbu-common-<customerid>-<env>-rds
If you are still uncertain as to how to construct the base URL or the base URL you have constructed is not working as expected, submit a Support Request for further assistance.
