Connecting to Your Database
This final part walks you through using the wallet and SQLcl to establish a secure connection to your RDS ADW database. You will select a schema and service name, set the TNS_ADMIN variable, and verify successful connectivity.
In order to connect to your database, you will need:
a schema name and password
Choose a schema name and password from your
schemas.jsonfile.
- a service name
- Choose a service name from tnsnames.ora, something like
<name>_low.
Login to your RDS ADW database
using:
sql mfcs_rds_custom@<name>_low
