Assumptions
You have a list of table names to export.
You have a read/write prefix-level PAR URI for an Oracle Object Storage bucket.
You want to export each table as JSON – CSV has issues with null in the last column.
Each table’s data will be stored under a URI path like <PAR_URI>/table_name.
You will use DBMS_CLOUD.EXPORT_DATA for export and DBMS_CLOUD.COPY_DATA for import.
Multi-part and timestamped files will be generated during export.
You are importing into existing tables with matching structures in the destination ADW.
