B Using FTS: An Example
Overview
This chapter provides an example of an API that provides a set of functions and procedures to facilitate data export from a database query to object store using FTS. The API consists of four main components:
get_idcs_token: Obtains an IDCS token for authentication.generate_par: Generates a Pre-Authenticated Request (PAR) for uploading data to an object store.put_object_in_store: Uploads a BLOB to object store using a PAR.export_query_to_blob: Exports the result of a database query to a BLOB.
Functions and Procedures
get_idcs_token
- Purpose: Obtain an IDCS token for authentication.
- Parameters:
p_idcs_url: IDCS URL.p_idcs_client_id: IDCS client ID.p_idcs_client_secret: IDCS client secret.p_scope_suffix: IDCS scope suffix.
- Return Value: IDCS token (VARCHAR2).
- Raises:
INVALID_IDCS_CREDENTIALSif the IDCS credentials are invalid.
generate_par
- Purpose: Generate a Pre-Authenticated Request (PAR) for uploading data to an object store.
- Parameters:
p_base_url: Base URL of object store.p_tenant: Tenant ID.p_idcs_token: IDCS token obtained usingget_idcs_token.p_os_prefix: Object store prefix.p_file_name: File name to be uploaded.
- Return Value: PAR access URI (VARCHAR2).
- Raises:
PAR_GENERATION_FAILEDif PAR generation fails.
put_object_in_store
- Purpose: Upload a BLOB to object store using a PAR.
- Parameters:
p_access_uri: PAR access URI obtained usinggenerate_par.p_blob_data: BLOB data to be uploaded.
- Raises:
UPLOAD_FAILEDif the upload fails.
- Purpose: Export the result of a database query to a BLOB.
- Parameters:
p_sql_query: SQL query to be executed.
- Return Value: BLOB containing the query results.
- Raises:
QUERY_EXECUTION_FAILEDif the query execution fails.
Example Usage
DECLARE
l_idcs_token VARCHAR2(4000);
l_par_uri VARCHAR2(32767);
l_blob_data BLOB;
BEGIN
l_idcs_token := get_idcs_token('https://idcs-url.com', 'client-id', 'client-secret', 'scope-suffix');
l_par_uri := generate_par('https://object-store-url.com', 'tenant-id', l_idcs_token, 'os-prefix', 'file-name.csv');
l_blob_data := export_query_to_blob('SELECT * FROM my_table');
put_object_in_store(l_par_uri, l_blob_data);
END;Error Handling
The API raises specific exceptions for each function/procedure, allowing the caller to handle errors accordingly. The exceptions are:
INVALID_IDCS_CREDENTIALSPAR_GENERATION_FAILEDUPLOAD_FAILEDQUERY_EXECUTION_FAILED
These exceptions can be caught and handled using standard PL/SQL error handling mechanisms.
Securely Obtaining an IDCS Token
Overview
The get_idcs_token_for_planning_app function provides a secure way to
obtain an IDCS token for the Planning App. This function is designed to be used by
authorized users and applications, and it abstracts away the underlying complexity of
obtaining an IDCS token.
Security Considerations
- The
get_idcs_token_for_planning_appfunction is a privileged function that has access to sensitive information, such as the IDCS client ID and client secret. Therefore, execute permission on this function is restricted to authorized users and applications. - The function does not expose the underlying IDCS client ID and client secret, ensuring that these sensitive values are not compromised.
Using the get_idcs_token_for_planning_app Function
To obtain an IDCS token securely using the
get_idcs_token_for_planning_app function, follow these steps:
- Ensure that you have the necessary execute permission on the
get_idcs_token_for_planning_appfunction. - Call the
get_idcs_token_for_planning_appfunction using a secure connection (for example, over a secure database connection). - The function will return a valid IDCS token that can be used for authentication and authorization purposes.
Using the export_query_to_object_store Procedure
The export_query_to_object_store procedure is a template that exports
the result of a SQL query to object store. To use this procedure, you need to replace
the hardcoded placeholders with your actual values.
Prerequisites
- The
get_idcs_token_for_planning_app,export_query_to_blob,generate_par, andput_object_in_storefunctions/procedures are available and properly configured. - The object store is properly set up and accessible.
Usage
To use the export_query_to_object_store procedure, simply call it with
the SQL query you want to export as an argument.
BEGIN
export_query_to_object_store('SELECT * FROM my_table');
END;Customization
Before using this procedure, you need to modify the
export_query_to_object_store procedure to replace the hardcoded
placeholders with your actual values. These placeholders include:
- Object store prefix
- Base URL
- Tenant ID
- IDCS URL
- File name
You should update the procedure to use your specific values for these placeholders.
Example
Suppose you want to export the result of a query to an object store with a prefix of
my_prefix, base URL of https://example.com, tenant
ID of my_tenant, and file name of my_file.csv. You
would need to modify the export_query_to_object_store procedure to use
these values.
Once you have customized the procedure, you can use it to export your query results to the object store.
get_idcs_token
CREATE OR REPLACE FUNCTION get_idcs_token(
p_idcs_url IN VARCHAR2,
p_idcs_client_id IN VARCHAR2,
p_idcs_client_secret IN VARCHAR2,
p_scope_suffix IN VARCHAR2
) RETURN VARCHAR2
IS
l_response CLOB;
l_token VARCHAR2(4000);
idcs_base_64_identity VARCHAR2(2000);
BEGIN
idcs_base_64_identity := REPLACE(REPLACE(REPLACE(UTL_ENCODE.TEXT_ENCODE(p_idcs_client_id || ':' || p_idcs_client_secret, 'WE8ISO8859P1', UTL_ENCODE.BASE64), CHR(9)), CHR(10)), CHR(13));
APEX_WEB_SERVICE.G_REQUEST_HEADERS.DELETE;
APEX_WEB_SERVICE.G_REQUEST_HEADERS(1).NAME := 'Authorization';
APEX_WEB_SERVICE.G_REQUEST_HEADERS(1).VALUE := 'Basic ' || idcs_base_64_identity;
APEX_WEB_SERVICE.G_REQUEST_HEADERS(2).NAME := 'Content-Type';
APEX_WEB_SERVICE.G_REQUEST_HEADERS(2).VALUE := 'application/x-www-form-urlencoded; charset=UTF-8';
l_response := APEX_WEB_SERVICE.MAKE_REST_REQUEST(
p_url => p_idcs_url,
p_http_method => 'POST',
p_parm_name => APEX_UTIL.STRING_TO_TABLE('grant_type:scope'),
p_parm_value => APEX_UTIL.STRING_TO_TABLE('client_credentials,rgbu:rpas:psraf-' || p_scope_suffix, ',')
IF l_response IS NULL THEN
RAISE_APPLICATION_ERROR(-20001, 'Failed to retrieve IDCS token. Response is null.');
END IF;
BEGIN
APEX_JSON.PARSE(l_response);
l_token := APEX_JSON.GET_VARCHAR2(p_path => 'access_token');
EXCEPTION
WHEN OTHERS THEN
RAISE_APPLICATION_ERROR(-20002, 'Failed to parse IDCS token response: ' || SQLERRM);
END;
IF l_token IS NULL THEN
RAISE_APPLICATION_ERROR(-20003, 'IDCS token is null.');
END IF;
RETURN l_token;
EXCEPTION
WHEN OTHERS THEN
RAISE_APPLICATION_ERROR(-20004, 'Error getting IDCS token: ' || SQLERRM);
END get_idcs_token;generate_par
CREATE OR REPLACE FUNCTION generate_par(
p_base_url IN VARCHAR2,
p_tenant IN VARCHAR2,
p_idcs_token IN VARCHAR2,
p_os_prefix IN VARCHAR2,
p_file_name IN VARCHAR2
) RETURN VARCHAR2
IS
l_response CLOB;
l_req_body CLOB;
l_access_uri VARCHAR2(32767);
BEGIN
-- Create the JSON request body for FTS invocation
l_req_body := create_par_request_body(p_os_prefix, p_file_name);
-- Get PAR from FTS service
l_response := apex_web_service.make_rest_request(
p_url => p_base_url || '/' || p_tenant || '/RetailAppsReSTServices/services/private/FTSWrapper/upload',
p_body => l_req_body,
p_headers => apex_web_service.g_request_headers
-- Check if the response is not null
RAISE_APPLICATION_ERROR(-20001, 'Failed to generate PAR: null response');
END IF;
-- Parse the response
BEGIN
APEX_JSON.parse(l_response);
EXCEPTION
WHEN OTHERS THEN
RAISE_APPLICATION_ERROR(-20002, 'Failed to parse PAR response: ' || SQLERRM);
END;
-- Get the access URI from the response
l_access_uri := APEX_JSON.get_varchar2(p_path => 'parList[%d].accessUri', p0 => 1);
-- Check if the access URI is not null
IF l_access_uri IS NULL THEN
RAISE_APPLICATION_ERROR(-20003, 'Failed to generate PAR: null access URI');
END IF;
RETURN l_access_uri;
EXCEPTION
WHEN OTHERS THEN
RAISE_APPLICATION_ERROR(-20004, 'Failed to generate PAR: ' || SQLERRM);
END generate_par;put_object_in_store
CREATE OR REPLACE PROCEDURE put_object_in_store(
p_access_uri IN VARCHAR2,
p_blob_data IN BLOB
) AS
l_error_msg VARCHAR2(4000);
BEGIN
BEGIN
DBMS_CLOUD.PUT_OBJECT(
object_uri => p_access_uri,
contents => p_blob_data
EXCEPTION
WHEN OTHERS THEN
l_error_msg := 'Error uploading object to store: ' || SQLERRM;
-- Log the error
DBMS_OUTPUT.PUT_LINE(l_error_msg);
-- Re-raise the error
RAISE_APPLICATION_ERROR(-20001, l_error_msg);
END;
END put_object_in_store;export_query_to_blob
CREATE OR REPLACE FUNCTION export_query_to_blob(
p_sql_query IN VARCHAR2
) RETURN BLOB
IS
l_context apex_exec.t_context;
l_export apex_data_export.t_export;
l_blob_data BLOB;
BEGIN
BEGIN
l_context := apex_exec.open_query_context(
p_location => apex_exec.c_location_local_db,
p_sql_query => p_sql_query
EXCEPTION
WHEN OTHERS THEN
RAISE_APPLICATION_ERROR(-20001, 'Failed to open query context: ' || SQLERRM);
END;
BEGIN
l_export := apex_data_export.export (
p_context => l_context,
p_format => apex_data_export.c_format_csv
EXCEPTION
WHEN OTHERS THEN
apex_exec.close(l_context);
RAISE_APPLICATION_ERROR(-20002, 'Failed to export data: ' || SQLERRM);
END;
l_blob_data := l_export.content_blob;
RETURN l_blob_data;
EXCEPTION
WHEN OTHERS THEN
IF l_context IS NOT NULL THEN
END IF;
RAISE;
END export_query_to_blob;
