Example PL/SQL Block
DECLARE
c_base_uri VARCHAR2(4000) := '<PAR URI>/<prefix>'; -- same PAR URI used for export
c_table_list SYS.ODCIVARCHAR2LIST := SYS.ODCIVARCHAR2LIST('ITEM_LOC_SOH_EOD', 'ITEM_LOC_SOH', 'ITEM_LOC');
l_columnpath CLOB;
BEGIN
FOR i IN 1 .. c_table_list.COUNT LOOP
-- To guarantee a specific ordering of columns, use the ORDER BY
-- clause within the JSON_ARRAYAGG function. Column order in
-- columnpath must match table column ordering. First column in
-- columnpath matches first column in table.
SELECT JSON_ARRAYAGG('$.' || column_name)
WITHIN GROUP (ORDER BY column_id)
INTO l_columnpath
FROM user_tab_columns
WHERE table_name = c_table_list(i);
DBMS_OUTPUT.PUT_LINE('Importing ' || c_table_list(i) || ' to uri: ' || c_base_uri || '/' || LOWER(c_table_list(i)));
DBMS_CLOUD.COPY_DATA(
table_name => c_table_list(i),
credential_name => NULL,
file_uri_list => c_base_uri || '/' || LOWER(c_table_list(i)) || '*',
format => JSON_OBJECT('type' VALUE 'json', 'columnpath' VALUE l_columnpath)
END LOOP;
END;
