generate_par
CREATE OR REPLACE FUNCTION generate_par(
p_base_url IN VARCHAR2,
p_tenant IN VARCHAR2,
p_idcs_token IN VARCHAR2,
p_os_prefix IN VARCHAR2,
p_file_name IN VARCHAR2
) RETURN VARCHAR2
IS
l_response CLOB;
l_req_body CLOB;
l_access_uri VARCHAR2(32767);
BEGIN
-- Create the JSON request body for FTS invocation
l_req_body := create_par_request_body(p_os_prefix, p_file_name);
-- Get PAR from FTS service
l_response := apex_web_service.make_rest_request(
p_url => p_base_url || '/' || p_tenant || '/RetailAppsReSTServices/services/private/FTSWrapper/upload',
p_http_method => 'POST',
p_body => l_req_body,
p_headers => apex_web_service.g_request_headers
-- Check if the response is not null
IF l_response IS NULL THEN
RAISE_APPLICATION_ERROR(-20001, 'Failed to generate PAR: null response');
END IF;
-- Parse the response
BEGIN
APEX_JSON.parse(l_response);
EXCEPTION
WHEN OTHERS THEN
RAISE_APPLICATION_ERROR(-20002, 'Failed to parse PAR response: ' || SQLERRM);
END;
-- Get the access URI from the response
l_access_uri := APEX_JSON.get_varchar2(p_path => 'parList[%d].accessUri', p0 => 1);
-- Check if the access URI is not null
IF l_access_uri IS NULL THEN
RAISE_APPLICATION_ERROR(-20003, 'Failed to generate PAR: null access URI');
END IF;
RETURN l_access_uri;
EXCEPTION
WHEN OTHERS THEN
RAISE_APPLICATION_ERROR(-20004, 'Failed to generate PAR: ' || SQLERRM);
END generate_par;
