Step 1: Get the SQL_ID
Before you do anything else, identify the query using its SQL_ID. You can get it:
- From the application or APEX session logs
- Using a query on recent
activity:
SELECT sql_id, sql_text FROM gv$sql WHERE sql_text LIKE '%target_table%' AND last_active_time > SYSDATE - 1/24 ORDER BY last_active_time DESC;
