Summary: What to do Next
If you found…
- Bad access paths: Add indexes or rewrite joins.
- You won't be able to add indexes to replicated objects
- Mismatched estimates: Check stats and consider histograms.
- Temp spills: Filter earlier.
- Wrong join type: Add hints or use a different query shape.
- Stale plans: Consider SQL plan baselines or profiles.
