22 Configure Sites
Your Retail Digital Commerce instance initially has a single site. If you want to create other sites, you can do so by using the Admin REST API to create additional site objects.
Note that in order for requests to be routed to the correct site on your instance, each site must have a unique domain name. The topics in this section describe how to manage sites by creating, modifying, and deleting site objects.
