Configure Storefront SSO
Setting up storefront SSO involves the following steps:
This section applies to Open Storefront Framework
(OSF).
- Configure Retail Digital Commerce storefront SSO settings.
- Download the service provider entity descriptor from Retail Digital Commerce.
- Upload the service provider entity descriptor to the identity provider, then download the corresponding identity provider entity descriptor.
- Upload the identity provider entity descriptor to Retail Digital Commerce.
- Configure CORS to enable the identity provider to access Retail Digital Commerce resources.
- Modify the storefront so that the links for logging in and accessing an account direct the shopper to either the storefront or the identity provider, as appropriate.
- If your Retail Digital Commerce environment is running multiple sites, repeat this process for each new site you create.
These steps are described in the sections that follow.
Note that if you configure your storefront to use SSO exclusively and your identity provider allows multiple accounts to share the same email address, you should enable sharing of email addresses in Retail Digital Commerce as well. See Allow profiles to share an email address for information about how to do this. If you configure your storefront to support both SSO and standard logins, neither your identity provider nor Retail Digital Commerce should support sharing of email addresses.
Configure Retail Digital Commerce Storefront SSO Settings
Use the PUT /ccadmin/v1/merchant/samlSettings endpoint in the Admin API to configure Retail Digital Commerce
to use storefront SSO. The endpoint request body includes the following
properties that are used to create the service provider entity
descriptor:
enabled– Iftrue, support for SSO is enabled. Default isfalse.nameIdPolicyFormat– The SAML name ID policy to use. Default isurn:oasis:names:tc:SAML:2.0:nameid-format:persistent.
In addition, the request body can include several properties that control the SAML security policies that Retail Digital Commerce enforces. The values of these properties are used to create settings in the service provider entity descriptor:
signAuthnRequest– Iftrue, the SAML request message will be signed. Default istrue.nameIdPolicyAllowCreate– Iftrue, Retail Digital Commerce allows the identity provider to create persistent name identifiers for sessions. Default istrue.requireEncryptedAssertions– Iftrue, Retail Digital Commerce accepts SAML assertions from the identity provider only if they are encrypted. Default istrue. For security reasons, this should be set totruein your production environment.requireSignedResponse– Iftrue, Retail Digital Commerce accepts authorization responses from the identity provider only if they include a signature. Default istrue. For security reasons, this should be set totruein your production environment.
The following call enables and configures SSO on a Retail Digital Commerce instance:
PUT /ccadmin/v1/merchant/samlSettings HTTP/1.1
Authorization: Bearer <access_token>
"enabled": true,
"nameIdPolicyFormat": "urn:oasis:names:tc:SAML:2.0:nameid-format:persistent",
"requireEncryptedAssertions": true,
"requireSignedResponse": true,
"signAuthnRequest": true,
"nameIdPolicyAllowCreate": true
Note that it may take several minutes for the changes to propagate to the storefront server.
Download the Service Provider Entity Descriptors
Once you have configured SSO on your
Retail Digital Commerce instance, you can use the GET /ccstore/v1/merchant/samlSettings endpoint in the Store API to return service provider entity
descriptors. For example, if you send the following request:
GET /ccstore/v1/merchant/samlSettings HTTP/1.1
The response will be similar to this:
"spEntityDescriptor": "<service provider entity descriptor>",
"links": [
"rel": "self",
"href": "http://myserver.example.com:7002/ccstore/v1/merchant/samlSettings"
The entity descriptor is returned as the value of the spEntityDescriptor property. This value is an XML document
using a standard SAML 2.0 format for describing the configuration
of the service provider.
To return the entity descriptor in
Base64 encoding, call the endpoint with the encode query parameter set to true:
GET /ccstore/v1/merchant/samlSettings?encode=true HTTP/1.1
Authorization: Bearer <access_token>Save the value of spEntityDescriptor as a standalone
document. Note that you need to create separate service provider
entity descriptors for the preview context and the live context,
as they will need to be registered with the identity provider as
separate service providers.
Register the Service Providers with the Identity Provider
Register the two service providers (the preview context and the live context) with the identity provider. (Register both service providers with the same identity provider; do not create multiple identity providers.) Depending on the API or other tools the identity provider supplies for this purpose, you register the service providers either by uploading the service provider entity descriptor documents that you downloaded from Retail Digital Commerce, or by manually configuring the identity provider with the data from the documents.
Once you have registered the service providers, download the identity provider entity descriptor. There should be only one identity provider entity descriptor, which applies to both the preview context and the live context. The identity provider entity descriptor should be a Base64-encoded XML file. If the generated file is not Base64-encoded, encode it before you upload it to Retail Digital Commerce.
Upload the Identity Provider Entity Descriptor to Retail Digital Commerce
Use the PUT /ccadmin/v1/samlIdentityProviders/default endpoint to
upload the identity provider entity descriptor to Retail Digital
Commerce, and to map assertion attributes to profile properties. This
mapping enables automatic creation of shopper profiles in
The request body includes the following properties:
encodedIdpMetadata-- The Base64-encoded identity provider entity descriptor.loginAttributeName– The identity provider attribute that stores the shopper’s login name.emailAttributeName-- The identity provider attribute that stores the shopper’s email address.requiredAttributeToPropertyMap– A map in which the keys are identify provider attributes and the values are the names of the corresponding required Retail Digital Commerce profile properties.optionalAttributeToPropertyMap– A map in which the keys are identify provider attributes and the values are the names of additional (non-required) Retail Digital Commerce profile properties. (Optional.)
For example:
PUT /ccadmin/v1/samlIdentityProviders/default HTTP/1.1
"loginAttributeName": "uid",
"emailAttributeName": "email",
"encodedIdpMetadata": "<identity provider entity descriptor>",
"requiredAttributeToPropertyMap": {
"uid": "login",
"email": "email"
"optionalAttributeToPropertyMap": {
"fName": "firstName",
"lName": "lastName"
Configure CORS
To
allow the identity provider to make requests to a site running on
your Retail Digital Commerce instance, you must add the identity provider’s
domain to the list of domains for which the site supports
CORS. To do this, add the domain to the allowedOriginMethods property of the corresponding site object and specify GET
(for redirect requests) and POST. For example:
PUT /ccadmin/v1/sites/siteUS HTTP/1.1
x-ccasset-language: en
"properties": {
"allowedOriginMethods": {
"http://www.myIdentityProvider.com": "GET,POST"
See CORS support for more information about CORS.
Modify the Storefront
To enable shoppers to access SSO on your storefront, you must modify any widgets that handle login or registration. The necessary modifications depend on whether your storefront supports SSO exclusively or supports both SSO and standard logins:
- If your storefront supports SSO exclusively, provide login and registration links that redirect the shopper to the identity provider.
- If your storefront supports both standard logins and SSO, provide two sets of links, one set that directs the shopper to the standard login and registration and one set that directs the shopper to the identity provider.
By default, the Header Widget in Retail Digital Commerce includes a Login/Registration element with links to the standard login and registration. In addition, Retail Digital Commerce provides an SSO-specific SAML Login/Registration element. If your storefront supports SSO exclusively, you can replace the standard Login/Registration element with the SAML Login/Registration element. If your storefront supports both standard logins and SSO, you can include both login/registration elements in the widget. Note that the text and styling are identical in both elements, so if you do include both, you should modify one or both of them to make it clear which kind of login each supports.
Implement Storefront SSO for Multiple Sites
If your Retail Digital Commerce environment is running multiple sites, all sites must be configured with the same identity provider. However, in the identity provider, each site should be registered as a separate service provider. (There should actually be two service providers registered for each site, one for the preview context and one for the live context.)
For each
site, follow the instructions above to generate service provider entity
descriptors for the preview context and live context. If your
site URLs are differentiated by context root, pass the site
ID in the x-ccsite header when calling the
GET /ccstore/v1/merchant/samlSettings endpoint:
x-ccsite: <siteId> If your
site URLs are differentiated by domain or subdomain, you do not need
to pass the site ID in the header. Specifying the domain in
the URL when calling the GET /ccstore/v1/merchant/samlSettings endpoint will identify the site.
The entity ID and assertion consumer POST location in each site’s service provider entity descriptor should match the site's base URL. Register the service providers either by uploading the service provider entity descriptor documents that you downloaded from Retail Digital Commerce, or by manually configuring the identity provider with the data from the documents. Note that only a single identity provider is currently supported, so all service providers must be configured in the same identify provider.
After registering the service
providers, download the identity provider entity descriptor,
and then use the PUT /ccadmin/v1/samlIdentityProviders/default endpoint to upload it to Retail Digital Commerce. (There
should be only one identity provider entity descriptor for a Retail
Digital Commerce instance, regardless of the number of sites. If you
have already performed this step for one site, you can skip
it for other sites you add.) The identity provider entity descriptor
Digital Commerce.
In addition to adding
each site as a service provider, you must update the CORS
allowedOriginMethods property for each site to
include the identity provider.
