Create Folders for Third-Party Files
Retail Digital Commerce includes a folder named /thirdparty where you can upload files needed by third-party
services such as Apple Pay and Google Search.
This section applies to Open Storefront Framework
(OSF).
Files stored in the /thirdparty folder can
be accessed on your site. For example, if your site is www.example.com
and you upload a file named myfile.html, the file can be viewed at the following URL:
http://www.example.com/myfile.htmlYou can create subfolders of /thirdparty and
upload files to these subfolders using the Retail Digital Commerce
Admin API. For example, you could create a subfolder named
/thirdparty/myfolder, and upload the file
myfile.html to this subfolder. The file
would then be accessible at this URL:
http://www.example.com/myfolder/myfile.htmlTo create a subfolder of /thirdparty, issue
a POST request to the /ccadmin/v1/files/createFolder endpoint on the administration server. The request JSON for
this endpoint includes a single property, folder, for specifying the pathname, which must begin with /thirdparty.
For example, the following request creates a /myfolder subfolder of the /thirdparty folder:
POST /ccadmin/v1/files/createFolder HTTP 1.1
Authorization: Bearer <access_token>
"folder": "/thirdparty/myfolder"
If the folder creation is successful, the JSON payload in the response is empty.
