27 Customize Email Templates
Retail Digital Commerce provides FreeMarker templates you can use to customize the emails your store sends to shoppers.
FreeMarker is a Java template engine. You do not need to install FreeMarker in order to edit the template files. For information about FreeMarker templates, see the FreeMarker Manual at freemarker.org.
If your Retail Digital Commerce instance is running multiple sites, you can configure and customize templates on for each site. See Download and edit email templates to learn how to select a site when you download email templates and upload your changes. See Add a site to a template for information about site names and URLs in templates.
