Display a Contact’s Purchase Limit in a Widget
A contact’s purchase limit is available from the User view model; however, it is not included in the out-of-the-box widgets.
This section applies to Open Storefront Framework (OSF).
If you want to add a contact’s purchase limit to a widget, you can do so using code similar to the sample below:
widget.user().derivedOrderPriceLimit()
