Enable Preorder and Backorder Functionality
You can use the updateInventoryConfiguration endpoint to enable preorder and backorder functionality.
This section applies to Open Storefront Framework
(OSF).
By default, preorder and backorder functionality are disabled in
Retail Digital Commerce. This section describes how to use the updateInventoryConfiguration endpoint to enable preorder
and backorder functionality. Preorders and backorders are enabled
and disabled at the same time with the preorderBackorderEnabled property. You cannot enable or disable them separately.
The following sample request enables backorder and preorder functionality:
PUT /ccadmin/v1/merchant/inventoryConfiguration HTTP/1.1
Authorization: Bearer <access_token>
"preorderBackorderEnabled": true
