Export and Import Price Data
With this feature you can import and export the prices for products and SKUs and as part of import, you can create, update and delete the prices.
This section applies to Open Storefront Framework
(OSF).
You can import and export prices for products and SKUs. While importing price data, you can create, update and delete prices. For example, you may want to delete prices so that the price hierarchy can be obtained from the parent. Or you might want to remove a sale price to activate the list price.
The Prices plugin allows you to do the following:
- Create and update prices for products and SKUs from different price list groups.
- Provide prices for only the SKUs of a product with price changes.
When you issue a bulk request to import prices (and optionally
update, create or delete prices) with the importOperationCode property, the following applies:
- You can import and export prices using a JSON or CSV format for both standalone and bundle modes.
- The import process supports both simple and complex pricing schemes.
- The bulk import process supports the
priceListGroupIdandtypeproperties, in addition to thepriceListIdproperty. - You can configure the bulk price export using the
qparameter.
The following is an example of a price import process:
POST http://localhost:9080/ccadmin/v1/importProcess
"mode": "standalone",
"fileName": "BulkImportPrices.json",
"format": "json",
"uploadType": "bulkImport",
"id": "Prices"
}The following table lists the fields that are supported by the plugin, along with validations.
| Property Name | Type | Description | Required |
importOperationCode |
String |
Supported for import only. The following values are supported:
No |
productId |
string | The product ID. | Yes |
skuId |
string | The SKU ID. | No |
priceListId |
string | The price list ID. | Yes, but it is not required if a priceListgroupId and type are provided.
priceListGroupId |
string | The pricelist group ID.
No, unless the pricelistId property
has not been provided.
type |
string | The price type. | No, unless the pricelistId property
startDate |
date | The start date of the price's availability. | No |
endDate |
date | The date that the price expires. | No |
pricingScheme |
string |
The pricing scheme contains the following values:
Yes |
listPrice |
double | The product/SKU price. This must be provided
when the pricingScheme property equals the listPrice property.
No, unless the pricingScheme property is set to listPrice.
complexPrice |
repository object | The volume price information that contains an array of levels. | No, unless the pricingScheme property is set to bulkPrice or tieredPrice.
Understand complex price levels
The complex price entities are defined in the following table:
quantity |
long | The quantity needed to enable the price. |
price |
double | The price that is used when the quantity meets
the value defined in the quantity property.
