20 Implement Storefront Single Sign-On
Retail Digital Commerce enables you to integrate customer logins on your storefront with an external customer data store or identity management tool.
For example, suppose you have an existing informational website with a large number of customer accounts. When you create a new Retail Digital Commerce site, you may want to provide existing customers with accounts on the Retail Digital Commerce site.
Storefront Single Sign-On (SSO) is implemented using SAML (Security Assertion Markup Language) 2.0, which is an open-standard XML-based data-exchange format. Before setting up storefront SSO, you should be familiar with SAML 2.0. For information about SAML 2.0, see:
https://en.wikipedia.org/wiki/SAML_2.0The SAML 2.0 specification is available at:
http://docs.oasis-open.org/security/saml/v2.0/saml-core-2.0-os.pdfStorefront Single Sign-On (SSO) provides two main benefits:
- Your Retail Digital Commerce environment can share logins with another site or system, so that logging into one environment automatically logs a shopper into the other.
- If an unregistered shopper is logged into the external system, then the first time the shopper accesses the Oracle Retail Digital Commerce site, a shopper profile is automatically created.
There are two ways you can use SSO on your storefront:
- You can configure your storefront to use SSO exclusively. In this case, all shopper logins are maintained in the external system.
- You can configure your storefront to support both SSO and standard logins. In this case, the logins for shoppers using SSO are maintained in the external system, and the logins for other shoppers are maintained in Retail Digital Commerce.
This section describes both of these configurations and how to set them.
