Import Relationship Data
This plugin, which is available only in account-based environments, is used for importing the relationships between contacts and accounts.
This section applies to Open Storefront Framework
(OSF).
You can import account and profile relationship data from an external system. Note that only account-based contacts can be linked with profiles.
When you import relationship data using the Relationships plugin, you can perform the following:
- Create, update and delete a relationship between an account and
a profile using the
importOperationCodeattribute. - Generate email and webhooks whenever the relationship between a profile and an account changes.
Account and profile relationships are established by providing the following properties:
| Property Name | Type | Description | Required |
accountId |
string | The ID of the account organization. Ensure that
there is a valid organizationId value associated
with this account.
Yes, if an externalAccountId has not been provided.
contactId |
string | The ID of the account-based contact. Ensure that there is a valid account-based profile ID associated with this property. | Yes, if an externalContactId has not been provided.
externalAccountId |
string | The external ID of the account, which is referenced
by the externalOrganizationId property. This property
provides the value of the customerContactId, which
represents the contact ID in an external system.
Yes, if an accountId has not
been provided.
externalContactId |
string | The external ID of the contact, which is referenced
by the customerContactId property.
Yes, if a contactId property
importOperationCode |
string |
The following values are supported:
No |
primary |
boolean |
Denotes whether the account is the primary
or secondary organization of the contact. When primary is set to When a primary value is not provided and the relationship already exists (primary or secondary), it is not updated. If there is no relationship, the account will be added as a secondary organization. If you do not provide this property for an existing relationship, the existing relationship remains. |
No |
