Overview of Web Checkout System Integrations
When you integrate with a payment provider, the checkout process is typically managed by the Retail Digital Commerce storefront.
This section applies to Open Storefront Framework
(OSF).
For example, if you use the Credit Card Payment webhook, the gateway can transmit payment authorization, void, and refund requests to the payment provider. The provider processes these transactions, but does not handle the shopping cart.
Integrations based on the Generic Payment webhook can use the Retail Digital Commerce checkout process as well. For example, in the scenario described in Integrate with a Gift Card Payment Gateway, the Generic Payment webhook functions in a similar way to the Credit Card Payment webhook, and the checkout process is handled by the Retail Digital Commerce storefront.
The Generic Payment webhook, however, also supports integrations with external web checkout systems such as Amazon Payments or Stripe Checkout. When using one of these providers, some or all of the checkout experience, including the user interface, is delegated to it. Retail Digital Commerce passes the entire shopping cart to the external system, which is responsible for managing the checkout process and then sending the results back to Retail Digital Commerce.
To develop an integration with an external web checkout system, you need to do the following:
- Create a gateway extension. In the
gateway.jsonfile, setpaymentMethodTypestogeneric. - Customize the Retail Digital Commerce storefront widgets to redirect to the external system, and to handle the data that the external system returns.
- Customize the system to be able to transform the Retail Digital Commerce data into the form required by the payment provider.
This chapter describes how to integrate with a web checkout system. This process requires using the initiate and retrieve gateway transaction types to process the cart, and authorization to complete the order.
