Secure Webhooks
Webhook events are signed so that the system receiving the event can verify their authenticity.
This section applies to Open Storefront Framework
(OSF).
Webhook POST requests include an HMAC SHA512 signature
in the X-Oracle-CC-WebHook-Signature header.
This signature is calculated using the secret key to generate
a hash of the raw UTF-8 bytes of the body of the post. A base64
encoding is then used to turn the hash into a string. If your
secret key has been disclosed or compromised, you can generate
a new one.
To generate a new secret key:
- Click the Settings icon.
- Click Web APIs and display the Webhook tab.
- Click the type of webhook you want to configure.
- Under HMAC Authentication, click Reset.
The following is sample code for generating a HMAC SHA512 signature
from a secret key and content. In the case of webhooks, the
content String would be the complete, unaltered body of the
webhook POST request.
This or similar code can be used to verify that the message was sent by someone with access to the private key (presumably Oracle Retail Digital Commerce), and that the body of the message has not been altered after the fact:
import java.security.SignatureException;
import javax.crypto.Mac;
import javax.crypto.spec.SecretKeySpec;
* This class provides an example of calculating an HMAC SHA512
* signature in java.
public class CalcHmacSignature {
* Calculate an HMAC SHA512 signature.
* @param pSecretKey the secret key (in string form).
* @param pContent the content to create a signture for. For Commerce
* Cloud WebHooks this should be the complete, unmodified body of the post.
* @return The Base64-encoded HMAC SHA512 signature.
* @throws java.security.SignatureException if there's a problem
public static String getSignatureForBytes(String pSecretKey, String pContent)
throws java.security.SignatureException {
try {
// HMAC SHA512 key from the raw key bytes
SecretKeySpec keySpec = new
SecretKeySpec(javax.xml.bind.DatatypeConverter.parseBase64Binary(secretKey),
"HmacSHA512");
// get the Mac instance for HMAC SHA512
Mac mac = Mac.getInstance("HmacSHA512");
// initialize with our key spec
mac.init(keySpec);
// generate the signature from the UTF-8 bytes of the content
byte[] digest = mac.doFinal(pContent.getBytes("UTF-8"));
// base64-encode the hmac signature... there's a pre-JDK-8 one
// tucked away in javax.xml.bind. If using Java 8, use the new
// java.util.Base64 class instead.
return javax.xml.bind.DatatypeConverter.printBase64Binary(
digest);
} catch (Exception e) {
throw new SignatureException("Failed to generate signature: " +
e.getMessage());
public static void main(String[] args) throws SignatureException {
if (args.length != 2) {
System.out.println("Usage: CalcHmacSignature key content");
System.out.println();
System.out.println(" (Note that one shouldn't really have the key ");
System.out.println(" passed in on the command line.)");
System.exit(-1);
System.out.println("Signature: " + getSignatureForBytes(args[0],
args[1]));
