Understand Export and Import Endpoint Parameters
The exportProcess and importProcess endpoints contain the following request parameters:
This section applies to Open Storefront Framework
(OSF).
| Parameter | Description |
fileName |
The name of the file to read from or create during the process. This parameter is required except when performing an export or import in standalone mode. |
mode |
Indicates if the export or import is standalone or archived. This parameter is only required if using standalone mode. |
id |
The operation ID. This parameter is required when working in the standalone mode. |
format |
The format to use during the export or import. This parameter is used only when working in the standalone mode. |
items |
Applies only to export. A list of objects to
be exported. This array contains the format and id properties of the
export operation.
param |
Passes additional parameters to plug-ins. For example, you can speed up an import process by not looking for an existing item to update using the following: |
prettyPrintJson |
This is parameter is supported for all import
and export IDs. The value can be true or false, which is the default. If set to true, the exported JSON will be formatted. Note that this parameter is
supposed only for JSON formats.
headersList |
This parameter, which is supported for all import and export IDs, controls the headers of an exported CSV file. Note that this parameter is supported only for CSV files. |
exportFromRepository |
For Products, ProductsV2, Collections, Catalogs,
Prices and Promotions, only published data is exported. To export
unpublished data, set the value of this parameter to publishing.
q |
The q parameter filters records
for the total set of records. It supports conditional operators, such
as eq, ne, gt, ge, lt, le, AND, OR, etc. Use this parameter to restrict exported
records to 100 thousand.
update |
The value for this import parameter an be set
to true or false, which is the default.
If set to false, all records will be marked as create.
Using this parameter can speed up the import process when import data
contains only new records.
memberAssignmentEmailTemplate |
This email template import parameter can be used with Accounts and AccountsV2 IDs to trigger email when a member is added or removed from an account. |
accountDeactivatedEmailTemplate |
This email template import parameter can be used with Accounts and AccountsV2 IDs to trigger email whenever an account is deactivated. |
organization_site_available_v1 |
This email template import parameter can be used with Accounts and AccountsV2 Ids to trigger email when an account is reactivated or a new contract has been added. |
emailTemplate |
This email template import parameter can be used with Profiles IDs to trigger email when a new profile is created. |
siteId |
This email import parameter can be used with
Profiles IDs. When triggering email, the links or other details included
in the email are taken from the default site. To trigger email from
a different site context, pass in a different siteId using this parameter.
roleChangeEmailTemplate |
This email template import parameter is used with Profiles IDs to trigger email roles whenever a profile is changed. |
profileDeactivatedEmailTemplate |
This email template import parameter can be used with Profiles IDs to trigger email whenever a profile is deactivated. |
organizationChangeEmailTemplate |
This email template import parameter can be used by Profiles IDs to trigger email when a profile's account changes. |
triggerWebhook |
By default Shopper Profile Create or Shopper Profile Update webhooks are not triggered
when a profile is created or modified. However, you can use this import
parameter with Profiles IDs to trigger the webhook by setting this
flag to true.
Note that you can also import and export your custom properties.
Notification Webhooks for Export and Import
If you want to receive notification when an export or an import job completes, configure the Export or Import Complete webhooks as required for your external application. These webhooks contain links to status and export files for export processes, and status and failed record files for import processes.
- In the Retail Digital Commerce administration interface, click the Settings icon.
- Click Web APIs.
- Open the Import Complete or the Export Complete Event API.
- Enter the URL of your external application, as well as any authorization information necessary to access the system. Click Save.
