Understand REST Support for Split Shipping
To support the split shipping feature, updates have been made to the Profile and Orders resources in the Store REST API.
This section applies to Open Storefront Framework
(OSF).
These resources contain endpoints for managing shopper profiles and orders, respectively.
- For the Profile resources, support has been added for an alias property to identify addresses in the address book.
- For the Orders endpoints, support has been added for multiple
shipping groups, in the form of a
shippingGroupsarray, and for an alias property to identify the addresses contained in those shipping groups. Each of the Orders endpoints that take detailed order or cart information in their request payload support theshippingGroupsarray. All of the Orders endpoints that return detailed order information will return ashippingGroupsarray in the response as long as there are cart items associated with the shipping groups. If none of the shipping groups for a cart or order have cart items associated with them then theshippingGroupsarray is suppressed in the endpoint response. This will typically be the case for persisted carts (incomplete orders) that existed in the order repository before the split shipping feature was deployed.
Understand the shippingGroups Array
The shippingGroups array is supported in request and response
payloads when appropriate. In request payloads, it is optional. In
response payloads, it is returned as long as item relationships exist
for one or more shipping groups in the cart/order. Each object in
the shippingGroups array holds information about:
- The shipping address (
shippingAddressobject) for the shipping group. ThisshippingAddressobject has an alias property that identifies the address. - The shipping method (
shippingMethodobject) for the shipping group. - The item relationships (items array) for the shipping group.
- The unique ID of the shipping group (
shippingGroupId), if known.
Existing shippingAddress and shippingMethod Properties
Prior to the introduction of the split shipping feature, the Store
API endpoints only supported a single shipping group. All items in
the cart inherently belonged to that shipping group though the relationship
between shipping group and cart items was not established in the order
repository until the order was submitted. To that end, the pricing
and order-related endpoints supported specification of the shipping
address and shipping method for the default shipping group, via the shippingAddress and shippingMethod properties,
in the request and response payloads. For backwards compatibility
these properties continue to be supported in the request and response
payloads with the caveats described below.
the shippingAddress and shippingMethod properties are:
- Ignored if the
shippingGroupsarray is specified. - Used to set the shipping address and method of the first shipping
group in the
shippingGroupsarray when theshippingGroupsarray is not explicitly specified.
In response payloads, the shippingAddress and shippingMethod properties refer to the shipping
address and shipping method of the first shipping group in the shippingGroups array.
