Use Custom Properties in Loyalty Integration
The custom properties in loyalty need to follow a convention.
This section applies to OSF. This section applies to Open Storefront Framework (OSF).
Custom properties used in Retail Digital Commerce need to follow a naming convention, for example x_customProperty). You should change any custom properties you had created in the past to follow this convention. For example:
Older format New format
enrollToLoyalty occ_enrollToLoyalty
loyaltyTransactionId occ_loyaltyTransactionId
loyaltyPointsAccrued occ_loyaltyPointsAccrued
accruedPointType occ_accruedPointType
